Eutrac Irideon FPZ Exploded Diagrams
- Last updated
Save as PDF
Parts with a t 🎨 can have a suffix added for different colours. For example:
7191A3049 yoke (black)
7191A3049 -1 yoke (white)
7191A3049 -5 yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon FPZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
| 1 |
See breakdown |
Eutrac adapter assembly |
| 2 |
Factory Replacement Only
Why? |
Product label |
| 6 |
7191A2000 |
Gobo holder |
| 7 |
See breakdown |
Shutter gate |
| 8 |
See breakdown |
Lens tube |
| 9 |
HWM1812 |
Screw M3 x 30mm |
| 10 |
See breakdown |
Fixture body |
| 11 |
HW5831 |
Wavy washer |
| 12 |
7191A3042 |
Yoke bushing nut |
| 13 |
HW5548 |
Flat washer, black nylon |
Fixture body
Fixture body components
| No |
Part Number |
Description |
| 1 |
7191A3035 🎨 |
Rear housing cap |
| 2 |
7191A3029 |
Strain relief bracket |
| 3 |
HWM1142 |
Screw M3 x 6mm |
| 4 |
HW6758 |
Strain relief grip |
| 5 |
HW9498 |
Clip fastener |
| 6 |
HW9497 |
Stud fastener |
| 7 |
HWM1670 |
Screw M3 x 10mm |
| 8 |
7191A3032 🎨 |
LED housing |
| 9 |
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 10 |
7191A4044 |
COB holder insulator |
| 11 |
7191A4043 |
COB holder thermal pad |
| 12 |
7191B2002 |
COB holder |
| 13 |
7191A3002 🎨 |
Yoke bolt |
| 14 |
HW4251 |
Flat washer |
| 15 |
7191A4010 🎨 |
Yoke degree angle label |
| 16 |
7191A3034 🎨 |
Reflector housing |
| 17 |
HWM1809 |
Set screw M4 x 12mm |
| 18 |
HW469 (black)
HW487 (white) |
Flat washer nylon |
| 19 |
7192A4012 🎨 |
Yoke knob |
| 20 |
7191A3049 🎨 |
Yoke (bare) a |
| 21 |
HW6906 |
Bushing
(portable only) |
| 22 |
7191A4040 |
Reflector |
| 23 |
7191A4042 |
Lens |
| 24 |
7191A3062 |
Lens retainer spring |
| 25 |
7191A3001 |
Glider mounting bracket |
| 26 |
7063A4030 |
Glider |
| 27 |
HWM3112 |
Screw M3 x 5mm |
a Bare painted yoke not including labels. Not all labels can be ordered
Shutter Gate & Lens Tube
Complete Shutter Gate and Lens Tube
| Part Number |
Item |
| 7191A2001 🎨 |
Complete lens tube |
| 7191A2002 🎨 |
Complete shutter gate |
| HWM1812 |
Screw to assemble lens tube and shutter gate (2 required) |
Shutter gate components
| No |
Part Number |
Description |
| 1 |
HWM1817 |
Screw M2 x 8mm |
| 2 |
HWM1808 |
Screw M3 x 16mm |
| 3 |
7191A3009 |
Rotating gate bracket |
| 4 |
7191A3017 |
Locking key |
| 5 |
7191A3036 🎨 |
Rear housing |
| 6 |
HWM1142 |
Screw M3 x 6mm |
| 7 |
7191A3015 |
Locking plate |
| 8 |
7191A3014 |
Clamping disc |
| 9 |
7191A3025 |
Spring plate |
| 10 |
7063A3009 |
Gate plate |
| 11 |
7191A3020 |
Gate shim |
| 12 |
7063A2009 🎨 |
Shutter blade
(including handle) |
7063A4020 🎨 |
Shutter blade handle |
| 13 |
7063A3008 |
Divider plate |
| 14 |
7191A3013 |
Clamping plate |
| 15 |
7191A3037 🎨 |
Front housing |
| 16 |
7191A4004 🎨 |
Gobo cover |
Lens tube components
| No |
Part Number |
Description |
| 17 |
Contact ETC 🎨 |
Media holder |
| 18 |
HWM1148 |
Screw M2.4 x 5mm |
| 19 |
Contact ETC |
Magnet |
| 20 |
7191A4007 |
Silicone pad |
| 21 |
HWM2108 |
Screw M3 x 10mm |
| 22 |
Contact ETC🎨 |
Media holder bracket |
| 23 |
7191A4009 |
Zoom angle sticker |
| 24 |
7191A4003 🎨 |
Zoom lens knob |
| 25 |
7191A3033 🎨 |
Lens tube body |
| 26 |
7191A4001 |
Front lens holder 63mm |
| 27 |
7063A4076 |
Front lens 63mm |
| 28 |
7063A4077 |
Rear lens 40mm |
| 29 |
7191A3006 |
Light blocker bracket |
| 30 |
7191A4000 |
Rear lens holder 40mm |
| 31 |
7191A3005 |
Rear bracket |
Eutrac Adapter
Complete Track Adapter Assembly
| ETL |
7191A2004 🎨 |
| CE |
7191A2006 🎨 |
Track Adapter Components
| No |
Part Number |
Description |
| 1 |
7063A4070 |
Label voltage in/out (ETL) |
| 7063A4071 |
Label voltage in/out (CE) |
| 2 |
7191B7004 🎨 |
Track adapter (ETL) |
| 7191B7005 🎨 |
Track adapter (CE) |
| 3 |
HW1107 |
Screw #4 x 3/8 |
| 4 |
HWM1679 |
Screw M4 x 10mm |
| 5 |
HWM3112 |
Screw M3 x 5mm |
| 6 |
J2502 🎨 |
Adapter plate
Includes metal plate, 2 plastic collar halves, and screws |
| 8 |
7191A3040 |
PSU EMI shield
(CE only) |
| 9 |
HW6758 |
Strain relief |
| 10 |
7191A3041 |
Yoke bushing |
| 11 |
W6470 🎨 |
Fiberglass sleeve (per foot)
~ 1.5 ft / fixture |
| 12 |
HWM1666 |
Screw M3 x 5mm |
| 13 |
PS444 |
Power supply |
| 14 |
7191A3031 |
Standoff M3 x 1" |
| 16 |
7191B5601 |
Driver PCB |
| 17 |
7191A3030 |
Standoff M3 x 0.625" |
| 18 |
7191A4005 🎨 |
Track adapter housing |
COB Conversion Kit
If your Irideon FPZ was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
| COB Conversion Kit (excluding LED) |
7191K1015 |
Conversion kit contains the parts shown on the left (COB holder parts, new reflector, lens, and holder), plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
| Part Number |
Description |
| CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
