OneTrack DMX ETL Irideon FPZ Exploded Diagrams
Parts with a  ðŸŽ¨  can have a suffix added for different colours. For example:
7191A3049          yoke (black)
7191A3049 -1    yoke (white)
7191A3049 -5    yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon FPZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
No Part Number Description
1 See breakdown OneTrack DMX adapter (ETL)
2 Factory Replacement Only
Why?
Product label
6 7191A2000 Gobo holder
7 See breakdown Shutter gate
8 See breakdown Lens tube
9 HWM1812 Screw M3 x 30mm
10 See breakdown Fixture body
11 HW5831 Wavy washer
12 7191A3042   ðŸŽ¨ Yoke bushing nut
13 HW5548 Flat washer, black nylon
Fixture body
Fixture body components
1 7191A3035 ðŸŽ¨ Rear housing cap
2 7191A3029 Strain relief bracket
3 HWM1142 Screw M3 x 6mm
4 HW6758 Strain relief grip
5 HW9498 Clip fastener
6 HW9497 Stud fastener
7 HWM1670 Screw M3 x 10mm
8 7191A3032 ðŸŽ¨ LED housing
9 CR669-F LED 2700K Gallery
CR682-F LED 3000K
CR670-F LED 3000K Gallery
CR684-F LED 4000K
CR673-F LED 5000K
10 7191A4044 COB holder insulator
11 7191A4043 COB holder thermal pad
12 7191B2002 COB holder
13 7191A3002 ðŸŽ¨ Yoke bolt
14 HW4251 Flat washer
15 7191A4010 ðŸŽ¨ Yoke degree angle label
16 7191A3034 ðŸŽ¨ Reflector housing
17 HWM1809 Set screw M4 x 12mm
18 HW469 (black)
HW487 (white)
Flat washer nylon
19 7192A4012 ðŸŽ¨ Yoke knob
20 7191A3049 ðŸŽ¨ Yoke (bare) a
21 HW6906 Bushing
(portable only)
22 7191A4040 Reflector
23 7191A4042 Lens
24 7191A3062 Lens retainer spring
25 7191A3001 Glider mounting bracket
26 7063A4030 Glider
27 HWM3112 Screw M3 x 5mm
a Bare painted yoke not including labels. Not all labels can be ordered
Shutter Gate & Lens Tube
 Complete Shutter Gate and Lens Tube
Part Number Item
7191A2001 ðŸŽ¨ Complete lens tube
7191A2002 ðŸŽ¨ Complete shutter gate
HWM1812 Screw to assemble lens tube and shutter gate (2 required)
Shutter gate components
1 HWM1817 Screw M2 x 8mm
2 HWM1808 Screw M3 x 16mm
3 7191A3009 Rotating gate bracket
4 7191A3017 Locking key
5 7191A3036 ðŸŽ¨ Rear housing
6 HWM1142 Screw M3 x 6mm
7 7191A3015 Locking plate
8 7191A3014 Clamping disc
9 7191A3025 Spring plate
10 7063A3009 Gate plate
11 7191A3020 Gate shim
12 7063A2009 ðŸŽ¨ Shutter blade
(including handle)
  7063A4020 ðŸŽ¨ Shutter blade handle
13 7063A3008 Divider plate
14 7191A3013 Clamping plate
15 7191A3037 ðŸŽ¨ Front housing
16 7191A4004 ðŸŽ¨ Gobo cover
FPZ Lens Tube Exploded.jpg Lens tube components
17 Contact ETC ðŸŽ¨ Media holder
18 HWM1148 Screw M2.4 x 5mm
19 Contact ETC Magnet
20 7191A4007 Silicone pad
21 HWM2108 Screw M3 x 10mm
22 Contact ETC🎨 Media holder bracket
23 7191A4009 Zoom angle sticker
24 7191A4003 🎨 Zoom lens knob
25 7191A3033 🎨 Lens tube body
26 7191A4001 Front lens holder 63mm
27 7063A4076 Front lens 63mm
28 7063A4077 Rear lens 40mm
29 7191A3006 Light blocker bracket
30 7191A4000 Rear lens holder 40mm
31 7191A3005 Rear bracket
DMX OneTrack Adapter (ETL)
Complete Track Adapter Assembly
Irideon FPZ 120V 7191A2140
Irideon FPZ 277V 7191A2142
Irideon WLZ 120V 7192A2140
Irideon WLZ 277V 7192A2142
Track Adapter Components
1 J2558 ðŸŽ¨ Track adapter (120V)
J2559 ðŸŽ¨ Track adapter (277V)
2 HWM10141 Screw M2.2 x 8mm Plastite
3 HW6759 Strain relief
5 7191A3066 ðŸŽ¨ Yoke bushing
6 HWM10144 Screw M3 x 8mm Plastite
7 HWM10145 Screw M3 x 12mm Plastite
8 HWM10143 Screw M2.5 x 8mm Plastite
9 W6470 ðŸŽ¨ Fiberglass sleeve (per foot)
~ 1.5 ft / fixture
10 HWM10142 Screw M2.5 x 6mm Plastite
11 HWM3112 Screw M3 x 5mm
12 7191A3030 Standoff M3 x 0.625"
13 7191A3031 Standoff M3 x 1"
14 HWM1666 Screw M3 x 5mm Taptite
15 7191B5701 Driver PCB
16 7191B5612 Power supply
17 7191A4005 ðŸŽ¨ Track adapter housing
18 7191A4011 ðŸŽ¨ Control knob cap
