Eutrac Irideon WLZ Exploded Diagrams
Parts with a ðŸŽ¨ can have a suffix added for different colours. For example:
7191A3049          yoke (black)
7191A3049 -1    yoke (white)
7191A3049 -5    yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon WLZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
No Part Number Description
1 See breakdown Eutrac adapter assembly
2 Factory Replacement Only
Why?
Product label
6 HW5548 Flat washer, black nylon
8 HW5831 Wavy washer
9 7191A3042  Yoke bushing nut
11 See breakdown Fixture body
Fixture body
1 Contact ETC  🎨 Media holder
2 7191A4007 Silicone pad
3 HWM1148 Screw M2 x 5mm
4 HWM1808 Screw M3 x 16mm
5 OP2097 Fresnel lens
6 Contact ETC Magnet
7 Contact ETC  🎨 Front lens mount
8 7192A4026 Glass plate
CE only
9 7192A4027 Lens mount ring
10 7192A4009 ðŸŽ¨ Zoom label left
11 HW469 (black)
HW487 (white/silver)
Flat washer
12 7192A4012 ðŸŽ¨ Yoke knob
13 7191A3049 ðŸŽ¨ Yoke (bare) a
14 7191A4010 ðŸŽ¨ Yoke degree angle label
15 7192A4008 ðŸŽ¨ Back cap label
16 HWM1346 Screw M4 x 10mm
17 7192A3014 ðŸŽ¨ Zoom knob
18 HW5861 Flat washer
19 HW4251 Flat washer
20 7191A3002 Yoke bolt
21 7192A4010 ðŸŽ¨ Zoom label right
a Bare painted yoke not including labels. Not all labels can be ordered
22 7192A3012 ðŸŽ¨ Main housing
23 HWM3112 Screw M3 x 5mm
24 HWM2108 Screw M3 x 10mm
25 7192A4024 Isolator ring
26 7192A3026 Heat sink plate
27 HWM1670 Screw M3 x 10mm
28 7192A4000 Shaft bearing
29 HWM1142 Screw M3 x 6mm
30 7191A3029 Strain relief bracket
31 HW6758 Strain relief grip
32 HWM1149 Screw M4 x 6mm
33 HWM1551 Screw M4 x 16mm
34 7192A3013 ðŸŽ¨ Rear housing
35 7192A2010 Shaft assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
36 HWM1142 Screw M3 x 6mm
37 7191A4044 COB holder insulator
38 7191B2001 COB holder
39 CR669-F LED 2700K Gallery
CR682-F LED 3000K
CR670-F LED 3000K Gallery
CR684-F LED 4000K
CR673-F LED 5000K
40 7191A4043 COB holder thermal pad
41 7192A3017 Heat sink/LED mount
42 HW5861 Flat washer
43 7192A3018 Threaded rod
44 HWM1670 Screw M3 x 10mm
45 7192A4014 Threaded nut mount
46 7192A4001 Shaft roller a
47 7192A3027 Shaft roller screw
a Roller includes small rubber ring. Rings are not available separately, contact ETC for advice if ring is broken or lost
Eutrac Adapter
Complete Track Adapter Assembly
ETL 7191A2004 ðŸŽ¨
CE 7191A2006 ðŸŽ¨
Track Adapter Components
1 7063A4070 Label voltage in/out (ETL)
7063A4071 Label voltage in/out (CE)
2 7191B7004 ðŸŽ¨ Track adapter (ETL)
7191B7005 ðŸŽ¨ Track adapter (CE)
3 HW1107 Screw #4 x 3/8
4 HWM1679 Screw M4 x 10mm
5 HWM3112 Screw M3 x 5mm
6 J2502 ðŸŽ¨ Adapter plate
Includes metal plate, 2 plastic collar halves, and screws
8 7191A3040 PSU EMI shield
(CE only)
9 HW6758 Strain relief
10 7191A3041 Yoke bushing
11 W6470 ðŸŽ¨ Fiberglass sleeve (per foot)
~ 1.5 ft / fixture
12 HWM1666 Screw M3 x 5mm
13 PS444 Power supply
14 7191A3031 Standoff M3 x 1"
16 7191B5601 Driver PCB
17 7191A3030 Standoff M3 x 0.625"
18 7191A4005 ðŸŽ¨ Track adapter housing
COB Conversion Kit
If your Irideon WLZ was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
COB Conversion Kit (excluding LED) 7192K1015
Conversion kit contains the parts shown on the left (COB holder parts, plus zoom labels in both black and white, since these need to be removed to access the LED), plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
CR682-F LED 3000K
CR684-F LED 4000K
CR673-F LED 5000K
