OneTrack DMX ETL Irideon WLZ Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7191A3049 yoke (black)
7191A3049 -1 yoke (white)
7191A3049 -5 yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon WLZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
| 1 |
See breakdown |
OneTrack DMX adapter (ETL) |
| 2 |
Factory Replacement Only
Why? |
Product label |
| 6 |
HW5548 |
Flat washer, black nylon |
| 8 |
HW5831 |
Wavy washer |
| 9 |
7191A3042 🎨 |
Yoke bushing nut |
| 11 |
See breakdown |
Fixture body |
Fixture body
| No |
Part Number |
Description |
| 1 |
Contact ETC 🎨 |
Media holder |
| 2 |
7191A4007 |
Silicone pad |
| 3 |
HWM1148 |
Screw M2 x 5mm |
| 4 |
HWM1808 |
Screw M3 x 16mm |
| 5 |
OP2097 |
Fresnel lens |
| 6 |
Contact ETC |
Magnet |
| 7 |
Contact ETC 🎨 |
Front lens mount |
| 8 |
7192A4026 |
Glass plate
CE only |
| 9 |
7192A4027 |
Lens mount ring |
| 10 |
7192A4009 🎨 |
Zoom label left |
| 11 |
HW469 (black)
HW487 (white/silver) |
Flat washer |
| 12 |
7192A4012 🎨 |
Yoke knob |
| 13 |
7191A3049 🎨 |
Yoke (bare) a |
| 14 |
7191A4010 🎨 |
Yoke degree angle label |
| 15 |
7192A4008 🎨 |
Back cap label |
| 16 |
HWM1346 |
Screw M4 x 10mm |
| 17 |
7192A3014 🎨 |
Zoom knob |
| 18 |
HW5861 |
Flat washer |
| 19 |
HW4251 |
Flat washer |
| 20 |
7191A3002 |
Yoke bolt |
| 21 |
7192A4010 🎨 |
Zoom label right |
a Bare painted yoke not including labels. Not all labels can be ordered
| No |
Part Number |
Description |
| 22 |
7192A3012 🎨 |
Main housing |
| 23 |
HWM3112 |
Screw M3 x 5mm |
| 24 |
HWM2108 |
Screw M3 x 10mm |
| 25 |
7192A4024 |
Isolator ring |
| 26 |
7192A3026 |
Heat sink plate |
| 27 |
HWM1670 |
Screw M3 x 10mm |
| 28 |
7192A4000 |
Shaft bearing |
| 29 |
HWM1142 |
Screw M3 x 6mm |
| 30 |
7191A3029 |
Strain relief bracket |
| 31 |
HW6758 |
Strain relief grip |
| 32 |
HWM1149 |
Screw M4 x 6mm |
| 33 |
HWM1551 |
Screw M4 x 16mm |
| 34 |
7192A3013 🎨 |
Rear housing |
| 35 |
7192A2010 |
Shaft assembly |
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
| No |
Part Number |
Description |
| 36 |
HWM1142 |
Screw M3 x 6mm |
| 37 |
7191A4044 |
COB holder insulator |
| 38 |
7191B2001 |
COB holder |
| 39 |
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 40 |
7191A4043 |
COB holder thermal pad |
| 41 |
7192A3017 |
Heat sink/LED mount |
| 42 |
HW5861 |
Flat washer |
| 43 |
7192A3018 |
Threaded rod |
| 44 |
HWM1670 |
Screw M3 x 10mm |
| 45 |
7192A4014 |
Threaded nut mount |
| 46 |
7192A4001 |
Shaft roller a |
| 47 |
7192A3027 |
Shaft roller screw |
a Roller includes small rubber ring. Rings are not available separately, contact ETC for advice if ring is broken or lost
DMX OneTrack Adapter (ETL)
Complete Track Adapter Assembly
| Irideon FPZ 120V |
7191A2140 |
| Irideon FPZ 277V |
7191A2142 |
| Irideon WLZ 120V |
7192A2140 |
| Irideon WLZ 277V |
7192A2142 |
Track Adapter Components
| No |
Part Number |
Description |
| 1 |
J2558 🎨 |
Track adapter (120V) |
| J2559 🎨 |
Track adapter (277V) |
| 2 |
HWM10141 |
Screw M2.2 x 8mm Plastite |
| 3 |
HW6759 |
Strain relief |
| 5 |
7191A3066 🎨 |
Yoke bushing |
| 6 |
HWM10144 |
Screw M3 x 8mm Plastite |
| 7 |
HWM10145 |
Screw M3 x 12mm Plastite |
| 8 |
HWM10143 |
Screw M2.5 x 8mm Plastite |
| 9 |
W6470 🎨 |
Fiberglass sleeve (per foot)
~ 1.5 ft / fixture |
| 10 |
HWM10142 |
Screw M2.5 x 6mm Plastite |
| No |
Part Number |
Description |
| 11 |
HWM3112 |
Screw M3 x 5mm |
| 12 |
7191A3030 |
Standoff M3 x 0.625" |
| 13 |
7191A3031 |
Standoff M3 x 1" |
| 14 |
HWM1666 |
Screw M3 x 5mm Taptite |
| 15 |
7191B5701 |
Driver PCB |
| 16 |
7191B5612 |
Power supply |
| 17 |
7191A4005 🎨 |
Track adapter housing |
| 18 |
7191A4011 🎨 |
Control knob cap |
