Portable Irideon WLZ Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7191A3049 yoke (black)
7191A3049 -1 yoke (white)
7191A3049 -5 yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon WLZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
| 1 |
7191A2019 |
Portable collar |
| 2 |
M7412 |
RJ45 blind plug
(qty 2) |
| 3 |
Factory Replacement Only
Why? |
Driver box sticker
| 4 |
See breakdown |
Driver box |
| 5 |
HWM1611 |
Screw M4 x 8mm |
| 6 |
HW6906 |
Bushing |
| 7 |
See breakdown |
Fixture body |
Driver Box
Driver box components
| No |
Part Number |
Description |
| 1 |
7191A4114 🎨 |
Driver box housing top |
| 2 |
HW2340 |
Screw 6/32 x 3/8" Taptite |
| 3 |
7191A4011 🎨 |
Control knob cap |
| 4 |
HWM1832 |
Screw M2.5 x 6mm |
| 5 |
7191B5603-CFG |
LED driver PCB - original |
| 7191B5703-CFG |
LED driver PCB - Plus |
| 6 |
PS444 |
Power supply - original
(pictured) |
| 7191B5612 |
Power supply - Plus
(original pictured) |
| 7 |
HW6758 |
Strain relief - LED output |
| 8 |
7191A4115 🎨 |
Driver box housing bottom |
| 9 |
HW6760 |
Strain relief - mains input
(qty 2) |
Fixture body
| No |
Part Number |
Description |
| 1 |
Contact ETC 🎨 |
Media holder |
| 2 |
7191A4007 |
Silicone pad |
| 3 |
HWM1148 |
Screw M2 x 5mm |
| 4 |
HWM1808 |
Screw M3 x 16mm |
| 5 |
OP2097 |
Fresnel lens |
| 6 |
Contact ETC |
Magnet |
| 7 |
Contact ETC 🎨 |
Front lens mount |
| 8 |
7192A4026 |
Glass plate
CE only |
| 9 |
7192A4027 |
Lens mount ring |
| 10 |
7192A4009 🎨 |
Zoom label left |
| 11 |
HW469 (black)
HW487 (white/silver) |
Flat washer |
| 12 |
7192A4012 🎨 |
Yoke knob |
| 13 |
7191A3049 🎨 |
Yoke (bare) a |
| 14 |
7191A4010 🎨 |
Yoke degree angle label |
| 15 |
7192A4008 🎨 |
Back cap label |
| 16 |
HWM1346 |
Screw M4 x 10mm |
| 17 |
7192A3014 🎨 |
Zoom knob |
| 18 |
HW5861 |
Flat washer |
| 19 |
HW4251 |
Flat washer |
| 20 |
7191A3002 |
Yoke bolt |
| 21 |
7192A4010 🎨 |
Zoom label right |
a Bare painted yoke not including labels. Not all labels can be ordered
| No |
Part Number |
Description |
| 22 |
7192A3012 🎨 |
Main housing |
| 23 |
HWM3112 |
Screw M3 x 5mm |
| 24 |
HWM2108 |
Screw M3 x 10mm |
| 25 |
7192A4024 |
Isolator ring |
| 26 |
7192A3026 |
Heat sink plate |
| 27 |
HWM1670 |
Screw M3 x 10mm |
| 28 |
7192A4000 |
Shaft bearing |
| 29 |
HWM1142 |
Screw M3 x 6mm |
| 30 |
7191A3029 |
Strain relief bracket |
| 31 |
HW6758 |
Strain relief grip |
| 32 |
HWM1149 |
Screw M4 x 6mm |
| 33 |
HWM1551 |
Screw M4 x 16mm |
| 34 |
7192A3013 🎨 |
Rear housing |
| 35 |
7192A2010 |
Shaft assembly |
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
| No |
Part Number |
Description |
| 36 |
HWM1142 |
Screw M3 x 6mm |
| 37 |
7191A4044 |
COB holder insulator |
| 38 |
7191B2001 |
COB holder |
| 39 |
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 40 |
7191A4043 |
COB holder thermal pad |
| 41 |
7192A3017 |
Heat sink/LED mount |
| 42 |
HW5861 |
Flat washer |
| 43 |
7192A3018 |
Threaded rod |
| 44 |
HWM1670 |
Screw M3 x 10mm |
| 45 |
7192A4014 |
Threaded nut mount |
| 46 |
7192A4001 |
Shaft roller a |
| 47 |
7192A3027 |
Shaft roller screw |
a Roller includes small rubber ring. Rings are not available separately, contact ETC for advice if ring is broken or lost
COB Conversion Kit
If your Irideon WLZ was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
| COB Conversion Kit (excluding LED) |
7192K1015 |
Conversion kit contains the parts shown on the left (COB holder parts, plus zoom labels in both black and white, since these need to be removed to access the LED), plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
| Part Number |
Description |
| CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
