Source Four LED Series 1&2 Exploded Diagrams
The variants of Source Four LED Series 1 (Lustr+, Tungsten, Daylight, Studio) and Series 2 (Lustr, Tungsten HD, Daylight HD) share most of their parts in common. Differences are called out below
Parts with a  🎨 can have a suffix added for different colours. For example:
7460A3011        yoke (black)
7460A3011-1    yoke (white)
7460A3011-5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Yoke and outer body
No Part Number Description
1 HW8144 🎨 Tilt lock handle
2 HW5126 Flat washer
3 7460A3011 ðŸŽ¨ Yoke (bare)a
4 HW5832 Screw, shutter barrel top
5 HW5125 Bolt, tilt lock
6 7060A4008-01 Thumb screw, shutter barrel bottom
7 HW5193 Bolt 5/16"
a Bare painted yoke not including labels. Not all labels can be ordered
Outer housing
9 7460A2005 🎨
Main housing assembly (ETL) b
7460A2009 ðŸŽ¨ Main housing assembly (CE) b
10 HW4210 Screw 10/32"
2 per fixture, one not shown
11 HWM1950 Screw M4 x 8mm
12 7460A2006 Barrel rotation clip, bottom b
b The main housing assembly is riveted together, sub-parts are not user serviceable. Only the bottom barrel clip is screwed on
Control card
13 HW2220 Screw 6/32"
14 7461K1002-1.8.2 Control card (all Series 1; Series 2 Lustr)
7461K1009 Control card (Series 2 Tungsten and Daylight HD)
Z1458-F DMX chip
socketed chip on control card
15 HWM1950 Screw M4 x 8mm
16 7460A3009 Control card tray
PSU
17 HW196 Nut (CE only)
18 7460B2003 Power line filter (CE only)
19 HW196 Nut (all variants)
20 HW772 P-clip for spare fuse
21 F379-F Spare fuse 4A 5x20mm
22 HW2220 Screw 6/32"
23 7460A3015 Line filter tray (all Series 1; Series 2 Lustr)
7460A3084 Line filter tray (Series 2 Tungsten and Daylight HD)
24 HW2318 PSU standoff
25 7460K1008 Power supply (all Series 1)
7461K1008 Power supply (Series 2 Lustr only)
7461K1001 Power supply (Series 2 Tungsten and Daylight HD)
26 7460A4010 PSU insulator (all Series 1; Series 2 Lustr)
7460A4046 PSU insulator (Series 2 Tungsten and Daylight HD)
27 HWM1948 Screw M4 x 10mm
28 7460A3008 Power supply tray (all Series 1; Series 2 Lustr)
7460A3085 Power supply tray (Series 2 Tungsten and Daylight HD)
Mixing tube
29 7413A2002 Mixing tube assembly
30 HWM1663 Screw M4 x 20mm
31 HWM1668 Washer M4
32 7460A3081 Lens spring retainer
33 7460A4061 Glass primary optic
34 7460A4062 Glass optic holder
The hardware in this section is only for fixtures with a glass optic
If you need hardware for your plastic optic fixture, contact ETC tech service
Array and fan
35 7460A4049 Ribbon cable guide
36 7460A4053 Rubber trim (small)
37 HWM1609 Screw M5 x 10mm Taptite (fan)
38 HW1169 Mounting screws for DMX PCB (shown out of position)
39 7410B5615 DMX connector assembly
40 HWM2108 Screw M3 x 10mm for Powercon assembly
41 7460B5804 (ETL)
7460B5904 (CE)
Powercon assembly
42 7460A4022 Rubber trim (large)
43 7460A3007 Fan mount
44 7460B2001 Fan
45 7460A3087 Fan baffle (all Series 1; Series 2 Lustr)
7460A3041 Fan baffle (Series 2 Tungsten and Daylight HD)
46 7460A3004 Heatsink (Series 1)
7460A3086 Heatsink (Series 2)
47 HWM1949 Screw M4 x 16mm
48 See notes below LED array
49 HWM2235 Screw M3 x 10mm
Display, UI and rear housing
50 HWM1950 Screw M4 x 8mm
51 7460A4011 Intake cone
52 7410A3012 LCD support bracket
53 7460A4054 PCB pad
54 DS183-F LCD (inc ribbon cable)
55 7410A4012 Display window
56 See section below UI sticker
57 7460A3018 🎨
End cap metalwork (ETL)
7460A3028 🎨 End cap metalwork (CE)
58 7460B5602 UI interconnect PCB
59 7460A3010 Interconnect board clamp
UI Stickers
The UI sticker covers the rear of the housing, and contains the UI buttons within in. It includes a ribbon cable (not shown above) to connect to the UI interconnect PCB.
7460A2002 Series 1 Lustr+ UI sticker
7460A2010 Series 1 Studio HD UI sticker
7460A2004 Series 1 Tungsten UI sticker
7460A2003 Series 1 Daylight UI sticker
7460A2012 Series 2 Lustr UI sticker
7460A2017 Series 2 Tungsten HD UI sticker
7460A2018 Series 2 Daylight HD UI sticker
LED Arrays
  • Series 2 Lustr fixtures with glass optics (33) can have the LED array swapped with no additional hardware
  • Series 2 Lustr fixtures with a plastic optic require a glass optic conversion kit, which includes a new LED array and all necessary parts for the conversion
  • Series 2 Tungsten HD and Daylight HD arrays are no longer available. Contact ETC tech service
  • Series 1 fixtures can no longer be upgraded to glass optics due to parts availability. Contact ETC tech service if you have a Series 1 fixtures with a failed array
7461K1003  Series 2 Lustr LED array PCB
(for existing glass optics only)
7461K1006 Series 2 Lustr glass optic kit
