Source Four LED Series 3 Exploded Diagrams
The variants of Source Four LED Series 3 (Lustr X8 and Daylight HD) share most of their parts in common. Differences are called out below
Parts with a  🎨  can have a suffix added for different colours. For example:
7460A3011        yoke (black)
7460A3011-1    yoke (white)
7460A3011-5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Handle
No Part Number Description
1 7462K1023 ðŸŽ¨ Handle kit (handle and 2 screws) a
 a Handles can only be fitted on fixtures which have the 2 necessary screw holes in the metalwork. Early fixtures were made without these holes, and cannot accept handles
Top casing and wireless parts
2 HW5832 Top barrel screw
3 HWM1971
or
HW4261
Top casing screw b
4 7462B5609 NFC PCB
icons8-no-camera.png 7462A4013 NFC sticker c
not pictured
5 N1084 Multiverse antenna
6 7060A4008-01 Bottom barrel thumb screw
b see Revisions before ordering
c NFC PCB is held in place by NFC sticker, order new sticker if replacing PCB
Top casing assembly
7 7462A3008  ðŸŽ¨
Top casing (ETL)
7462A3052 ðŸŽ¨ Top casing (CE)
8 HWM1950
Screw M4 x 8mm
9 7462B2002
Line filter
(CE only)
10 7462B5607 DMX PCB
11 7462B5608 Power input PCB
12 HWM1133 Screw M2.9 x 12mm
for DMX PCB
13 HWM2108 Screw M3 x 10mm
for power PCB
14 7413A3004 Barrel rotation clip
15 7060A4010 Bushing gate
Control / UI PCB
16 HW2188 Screw 6/32 x 1/2
17 See below Control card PCB
18 7462A3013 UI tray
19 7462A4020 UI label (Lustr X8)
7462A4063  UI label (Daylight HD)
20 7470A2001 Encoder knob cap
PSU and mixing tube
21 HWM1971 Screw M4 x 12mm
(attaches array assembly to bottom casing)
22 HWM1950 Screw M4 x 8mm
23 7462A3012 PSU tray
24 7462A3025 PSU bottom tray
25 7462A4012 PSU insulator
26 7462K1013 PSU
27 HWM1671 Screw M3.5 x 6mm
28 7462A2013 Mixing tube assembly
29 7462A3014 Blocker plate
Array and fans
30 HWM10002 Screw M4 x 6mm
31 Kit, see below LED array PCB kit
32 HW6129 Grommet
33 HWM1609 Screw M5 x 10mm (driver fan)
34 7462A4015 Array thermal pad
(included in array kit)
35 7462A2001 LED heatsink
36 7462B2001 Fan (array)
37 7462A3001 Fan spring
38 7462A3015 Heatsink mount
39 7462B2003 Fan (driver board) b
Driver and distro PCBs
40 7462A3011 Driver tray
41 HWM1950 Screw M4 x 8mm
42 Kit, see below Driver PCB kit
43 HW2220 Screw 6/32 x 5/16
44 7462A4021 Distro cover
45 7462B5606 Distro PCB
46 7462A4022 Distro insulator pad
Yoke
47 HWM2319 Tilt lock bolt
48 N1111 Multiverse antenna mount
49 7460A3011 🎨 Yoke (bare) a
50 7462A3007  ðŸŽ¨
7462A3051  🎨
Bottom casing (ETL)
See Revisions
7462A3051 Bottom casing (CE)
See Revisions
51 HW5914 Tilt lock washer
52 HWM8014 Tilt lock handle
53 HW5193 Yoke bolt
54 HW5126 Yoke bolt washer
55 HWM1986 Screw M4 x 8mm b
56 7470A3019 Clutch plate
57 7413A3004 Barrel rotation clip
58 7060A4010 Bushing gate
59 HWM1950 Screw M4 x 8mm
a Bare painted yoke not including labels. Not all labels can be ordered
LED control card, driver card and array information
The control card (UI), LED driver card, and LED array can be exchanged independently of each other, bearing in mind the compatibility exceptions below
Compatibility
Some control cards and driver boards have additional compatibility considerations. See here for how to select the correct parts:
Compatibility of Driver and Control Cards for Series 3
42 7462K1003 LED driver PCB
17 7462K1004-x.x.x Control / UI PCB
31 7462K1001-x.x.x LED array PCB (Lustr X8)
31 7462K1002-x.x.x LED array PCB (Daylight HDR)
-x.x.x represents the firmware version pre-installed on the control card. Contact your dealer or ETC office to see which version is currently shipping
