Eutrac Source Four Mini LED Exploded Diagrams
Parts with a 🎨 can have a suffix added for different colours. For example:
7063A3006         yoke (black)
7063A3006-1    yoke (white)
7063A3006-5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Source Four Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
No Part Number Description
1  7063A3006  🎨 Yoke (bare) a
2 7063A4073 🎨 Sticker "ceiling track only"
3 HWM1688 Screw M5 x 16mm
4 See breakdown Track adapter assembly
5 See breakdown Burner assembly
6 7191A4003 ðŸŽ¨ Shutter barrel knob
7 See breakdown Shutter barrel
8 7063A2010  Gobo holder
9 HWM305 Screw M3 x 8mm
10 HW4216 Flat washer
11 7192A4012 ðŸŽ¨ Tilt lock knob
12 7063A4070 Label voltage in/out (ETL)
7063A4071 Label voltage in/out (CE)
13 HW6747🎨 Track retaining collar (not shown) and retaining washer b
14 HW5821🎨 Jam nut 1/8
a Bare painted yoke not including labels. Not all labels can be ordered
b Includes 2 components, retaining collar shown in "Eutrac adapter" section below
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
Burner assembly components
1 7063A4030 Glider piece
2 7063A3023 Bracket 2
3 HWM304 Screw M3 x 6mm
4 7191A3062 Lens retainer spring
5 7063A4091 Reflector lens
6 7063A3066 Reflector
7 7063A4065 Reflector shim
8 7063A3045 ðŸŽ¨ Housing metalwork
10 7063A4092 COB holder insulator
11 7063B7019 COB holder 10" wires a
7063B7020 COB holder 14" wires a
7163B7119 COB holder 17" wires a
12
CR669-F LED 2700K Gallery
CR682-F LED 3000K
CR670-F LED 3000K Gallery
CR684-F LED 4000K
CR673-F LED 5000K
13 7063A4090 COB thermal pad
14 7063A3044 ðŸŽ¨ Rear end/heatsink
15 HWM1011 Screw M3 x 12mm
16 7063A3046 ðŸŽ¨ Strain relief
17 HWM2105 Screw M3 x 10mm
18 W6470 ðŸŽ¨ Fibreglass sleeve
(order 1 foot per fixture and snip)
19
7063A4083 ðŸŽ¨ Handle label Gallery b
7063A4059 ðŸŽ¨ Handle label 3000K c
7063A4078 ðŸŽ¨ Handle label 4000K
7063A4079 ðŸŽ¨ Handle label 5000K
20 7063A4054 ðŸŽ¨ Rear handle
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
 Complete shutter barrels
Original (non-Plus) 7063A2000 ðŸŽ¨
Source 4 Mini Plus 7163A2000 ðŸŽ¨
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
1 HWM1142 Screw M3 x 6mm
(slot cover)
2 7063A3019 ðŸŽ¨ Gobo slot cover
3 HWM1684 Screw M3.5 x 14mm
4 7063A3033 ðŸŽ¨ Top half metalwork
5 7063A2011 ðŸŽ¨ Shutter assembly a
6 7063A3034 ðŸŽ¨ Bottom half metalwork
7
7063A4037 Product sticker
(original, black)
7063A4043 Product sticker
(original, white)
7163A4004 Product sticker
(Plus, black)
7163A4004-1 Product sticker
(Plus, white)
8 7063A4020 ðŸŽ¨ Shutter blade handle (single)
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
Eutrac Adapter
Complete Track Adapter Assembly
ETL 7063A2017 ðŸŽ¨
CE 7063A2206 ðŸŽ¨
Track Adapter Components
1 7066A2001 ðŸŽ¨ Track adapter housing (ETL)
7066A2201 ðŸŽ¨ Track adapter housing (CE)
2 HW6747🎨 Track retaining collar, and retaining washer (not shown) a
3 7063B5601 Driver PCB (ETL)
7063B5701 Driver PCB (CE)
4 HW122 Nutr 4-40
5 HW9185 Standoff 4-40 x 1"
a Includes 2 components, retaining washer shown in "top level components" section above
COB Conversion Kit
If your Source 4 Mini LED was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
COB Conversion Kit (excluding LED) 7063K1015
Conversion kit contains the parts shown on the left, plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
CR682-F LED 3000K
CR684-F LED 4000K
CR673-F LED 5000K
