F-Drive Portable Source Four Mini LED Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7063A3006 yoke (black)
7063A3006-1 yoke (white)
7063A3006-5 yoke (silver)
Plastic parts and stickers are generally only available on black or white
Source Four Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
This product was sold as "Source Four Mini F-Drive Portable" and then "Source Four Mini Plus F-Drive Portable". These products are identical apart from the label on the yoke, and the label on the shutter barrel (and hence the part number of the complete shutter barrel). We recommend replacing stickered parts like-for-like, but otherwise all parts are the same
Top level components
| No |
Part Number |
Description |
| 1 |
See breakdown |
Shutter barrel |
| 2 |
7063A2010 🎨 |
Gobo holder |
| 3 |
7192A4012 🎨 |
Tilt lock knob |
| 4 |
HW4216 |
Flat washer |
| 5 |
HWM1611 |
Screw M4 x 8mm |
| 7 |
7063A3006 🎨 |
Yoke (bare) a |
| 8 |
7191A4003 🎨 |
Shutter barrel knob |
| 9 |
See breakdown |
Burner assembly |
| 10 |
HWM1688 |
Screw M5 x 16mm |
| 11 |
7148A4073 🎨 |
F-Drive box bottom housing |
| 12 |
HW6759 |
Strain relief |
| 13 |
7148B5635 |
F-Drive PCB |
| 14 |
HWM1029 |
Screw M4 x 8mm |
| 15 |
7184A4072 🎨 |
F-Drive box top housing |
a Bare painted yoke not including labels. Not all labels can be ordered
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
Burner assembly components
| No |
Part Number |
Description |
| 1 |
7063A4030 |
Glider piece |
| 2 |
7063A3023 |
Bracket 2 |
| 3 |
HWM304 |
Screw M3 x 6mm |
| 4 |
7191A3062 |
Lens retainer spring |
| 5 |
7063A4091 |
Reflector lens |
| 6 |
7063A3066 |
Reflector |
| 7 |
7063A4065 |
Reflector shim |
| 8 |
7063A3045 🎨 |
Housing metalwork |
| 9 |
HWM305 |
Screw M3 x 8mm |
| 10 |
7063A4092 |
COB holder insulator |
| 11 |
7063B7019 |
COB holder 10" wires a |
| 7063B7020 |
COB holder 14" wires a |
| 7163B7119 |
COB holder 17" wires a |
12
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 13 |
7063A4090 |
COB thermal pad |
| 14 |
7063A3044 🎨 |
Rear end/heatsink |
| 15 |
HWM1011 |
Screw M3 x 12mm |
| 16 |
7063A3046 🎨 |
Strain relief |
| 17 |
HWM2105 |
Screw M3 x 10mm |
| 18 |
W6470 🎨 |
Fibreglass sleeve
(order 1 foot per fixture and snip) |
19
7063A4083 🎨 |
Handle label Gallery b |
| 7063A4059 🎨 |
Handle label 3000K c |
| 7063A4078 🎨 |
Handle label 4000K |
| 7063A4079 🎨 |
Handle label 5000K |
| 20 |
7063A4054 🎨 |
Rear handle |
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
Complete shutter barrels
| Original (non-Plus) |
7063A2000 🎨 |
| Source 4 Mini Plus |
7163A2000 🎨 |
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
| No |
Part Number |
Description |
| 1 |
HWM1142 |
Screw M3 x 6mm
(slot cover) |
| 2 |
7063A3019 🎨 |
Gobo slot cover |
| 3 |
HWM1684 |
Screw M3.5 x 14mm |
| 4 |
7063A3033 🎨 |
Top half metalwork |
| 5 |
7063A2011 🎨 |
Shutter assembly a |
| 6 |
7063A3034 🎨 |
Bottom half metalwork |
7
7063A4037 |
Product sticker
(original, black) |
| 7063A4043 |
Product sticker
(original, white) |
| 7163A4004 |
Product sticker
(Plus, black) |
| 7163A4004-1 |
Product sticker
(Plus, white) |
| 8 |
7063A4020 🎨 |
Shutter blade handle (single) |
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
