OneTrack DMX ETL Source Four Mini LED Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7163A3000 yoke (black)
7163A3000 -1 yoke (white)
7163A3000 -5 yoke (silver)
Plastic parts and stickers are generally only available on black or white
Source Four Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
| 1 |
7163A3000 🎨 |
Yoke (bare) a |
| 2 |
Factory Replacement Only
Why? |
Driver box sticker
| 3 |
HWM1688 |
Screw M5 x 16mm |
| 4 |
See breakdown |
Track adapter assembly |
| 5 |
See breakdown |
Burner assembly |
| 6 |
7191A4003 🎨 |
Shutter barrel knob |
| 7 |
See breakdown |
Shutter barrel |
| 8 |
7063A2010 🎨 |
Gobo holder |
| 9 |
HWM305 |
Screw M3 x 8mm |
| 10 |
HW4216 |
Flat washer |
| 11 |
7192A4012 🎨 |
Tilt lock knob |
| 12 |
HW6759 |
Strain relief |
| 13 |
J2473 |
Adapter nipple 12mm |
| 14 |
HW5821 🎨 |
Jam nut 1/8 |
| 15 |
HW6752 🎨 |
Bushing female |
a Bare painted yoke - this version does not use stickers
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
Burner assembly components
| No |
Part Number |
Description |
| 1 |
7063A4030 |
Glider piece |
| 2 |
7063A3023 |
Bracket 2 |
| 3 |
HWM304 |
Screw M3 x 6mm |
| 4 |
7191A3062 |
Lens retainer spring |
| 5 |
7063A4091 |
Reflector lens |
| 6 |
7063A3066 |
Reflector |
| 7 |
7063A4065 |
Reflector shim |
| 8 |
7063A3045 🎨 |
Housing metalwork |
| 9 |
HWM305 |
Screw M3 x 8mm |
| 10 |
7063A4092 |
COB holder insulator |
| 11 |
7063B7019 |
COB holder 10" wires a |
| 7063B7020 |
COB holder 14" wires a |
| 7163B7119 |
COB holder 17" wires a |
12
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 13 |
7063A4090 |
COB thermal pad |
| 14 |
7063A3044 🎨 |
Rear end/heatsink |
| 15 |
HWM1011 |
Screw M3 x 12mm |
| 16 |
7063A3046 🎨 |
Strain relief |
| 17 |
HWM2105 |
Screw M3 x 10mm |
| 18 |
W6470 🎨 |
Fibreglass sleeve
(order 1 foot per fixture and snip) |
19
7063A4083 🎨 |
Handle label Gallery b |
| 7063A4059 🎨 |
Handle label 3000K c |
| 7063A4078 🎨 |
Handle label 4000K |
| 7063A4079 🎨 |
Handle label 5000K |
| 20 |
7063A4054 🎨 |
Rear handle |
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
Complete shutter barrels
| Original (non-Plus) |
7063A2000 🎨 |
| Source 4 Mini Plus |
7163A2000 🎨 |
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
| No |
Part Number |
Description |
| 1 |
HWM1142 |
Screw M3 x 6mm
(slot cover) |
| 2 |
7063A3019 🎨 |
Gobo slot cover |
| 3 |
HWM1684 |
Screw M3.5 x 14mm |
| 4 |
7063A3033 🎨 |
Top half metalwork |
| 5 |
7063A2011 🎨 |
Shutter assembly a |
| 6 |
7063A3034 🎨 |
Bottom half metalwork |
7
7063A4037 |
Product sticker
(original, black) |
| 7063A4043 |
Product sticker
(original, white) |
| 7163A4004 |
Product sticker
(Plus, black) |
| 7163A4004-1 |
Product sticker
(Plus, white) |
| 8 |
7063A4020 🎨 |
Shutter blade handle (single) |
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
DMX OneTrack Adapter (ETL)
Complete Track Adapter Assembly
| 120V |
7163A2141 |
| 277V |
7163A2041 |
Track Adapter Components
| No |
Part Number |
Description |
| 1 |
J2558 🎨 |
Track adapter (120V) |
| J2559 🎨 |
Track adapter (277V) |
| 2 |
HWM10141 |
Screw M2.2 x 8mm Plastite |
| 3 |
HW6759 |
Strain relief |
| 5 |
J2579 |
Yoke bushing |
| 6 |
HWM10144 |
Screw M3 x 8mm Plastite |
| 7 |
HWM10145 |
Screw M3 x 12mm Plastite |
| 8 |
HWM10143 |
Screw M2.5 x 8mm Plastite |
| 9 |
W6470 🎨 |
Fiberglass sleeve (per foot)
~ 1.5 ft / fixture |
| 10 |
HWM10142 |
Screw M2.5 x 6mm Plastite |
| No |
Part Number |
Description |
| 11 |
HWM3112 |
Screw M3 x 5mm |
| 12 |
7191A3030 |
Standoff M3 x 0.625" |
| 13 |
7191A3031 |
Standoff M3 x 1" |
| 14 |
HWM1666 |
Screw M3 x 5mm Taptite |
| 15 |
7191B5601 |
Driver PCB |
| 16 |
7191B5612 |
Power supply |
| 17 |
7191A4005 🎨 |
Track adapter housing |
| 18 |
7191A4011 🎨 |
Control knob cap |
