Portable Plus Source Four Mini LED Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7163A3000 yoke (black)
7163A3000 -1 yoke (white)
7163A3000 -5 yoke (silver)
Plastic parts and stickers are generally only available on black or white
Source Four Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
| 1 |
7191A3043 |
Support washer |
| 2 |
M7412 |
RJ45 blind plug
(qty 2) |
| 3 |
Factory Replacement Only
Why? |
Driver box sticker
| 4 |
See breakdown |
Driver box |
| 5 |
7163A3000 🎨 |
Yoke (bare) a |
| 6 |
HWM1169 |
Screw M3.5 x 6mm |
| 7 |
HW6906 |
Bushing |
| 8 |
HWM1688 |
Screw M5 x 16mm |
| 9 |
7192A4012 🎨 |
Tilt lock knob |
| 10 |
HW4216 |
Flat washer |
| 11 |
See breakdown |
Burner assembly |
| 12 |
7063A2010 🎨 |
Gobo holder |
| 13 |
See breakdown |
Shutter barrel |
| 14 |
7191A4003 🎨 |
Shutter barrel knob |
a Bare painted yoke - this version does not use stickers
Driver box
Complete driver boxes
| 240V with Schuko plug |
7163A2042 🎨 |
| 240V with UK plug |
7163A2043 🎨 |
| 120V with Edison plug |
7163A2044 🎨 |
Note: complete driver box comes with a pre-wired mains cable, but the LED output wiring of the existing fixture must be wired in, using the included strain relief. See also Repair Guide
Does not include the legend/product sticker - See part 3 in the "top level assembly"
Driver box components
| No |
Part Number |
Description |
| 15 |
I2170 🎨 |
Prop 65 Label (EN/FR)
ETL only |
| 16 |
HW2340 |
Screw 6/32 x 3/8" Taptite |
| 17 |
7191A4114 🎨 |
Driver box housing top |
| 18 |
HWM1832 |
Screw M2.5 x 6mm |
| 19 |
7191B5612 |
Power supply |
| 20 |
7191A4011 🎨 |
Control knob cap |
| 21 |
7191B5603-CFG |
LED driver PCB |
| 22 |
HW6759 |
Strain relief - LED output |
| 23 |
7191A4115 🎨 |
Driver box housing bottom |
| 24 |
HW6760 |
Strain relief - mains input
(qty 2) |
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
Burner assembly components
| No |
Part Number |
Description |
| 1 |
7063A4030 |
Glider piece |
| 2 |
7063A3023 |
Bracket 2 |
| 3 |
HWM304 |
Screw M3 x 6mm |
| 4 |
7191A3062 |
Lens retainer spring |
| 5 |
7063A4091 |
Reflector lens |
| 6 |
7063A3066 |
Reflector |
| 7 |
7063A4065 |
Reflector shim |
| 8 |
7063A3045 🎨 |
Housing metalwork |
| 9 |
HWM305 |
Screw M3 x 8mm |
| 10 |
7063A4092 |
COB holder insulator |
| 11 |
7063B7019 |
COB holder 10" wires a |
| 7063B7020 |
COB holder 14" wires a |
| 7163B7119 |
COB holder 17" wires a |
12
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 13 |
7063A4090 |
COB thermal pad |
| 14 |
7063A3044 🎨 |
Rear end/heatsink |
| 15 |
HWM1011 |
Screw M3 x 12mm |
| 16 |
7063A3046 🎨 |
Strain relief |
| 17 |
HWM2105 |
Screw M3 x 10mm |
| 18 |
W6470 🎨 |
Fibreglass sleeve
(order 1 foot per fixture and snip) |
19
7063A4083 🎨 |
Handle label Gallery b |
| 7063A4059 🎨 |
Handle label 3000K c |
| 7063A4078 🎨 |
Handle label 4000K |
| 7063A4079 🎨 |
Handle label 5000K |
| 20 |
7063A4054 🎨 |
Rear handle |
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
Complete shutter barrels
| Original (non-Plus) |
7063A2000 🎨 |
| Source 4 Mini Plus |
7163A2000 🎨 |
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
| No |
Part Number |
Description |
| 1 |
HWM1142 |
Screw M3 x 6mm
(slot cover) |
| 2 |
7063A3019 🎨 |
Gobo slot cover |
| 3 |
HWM1684 |
Screw M3.5 x 14mm |
| 4 |
7063A3033 🎨 |
Top half metalwork |
| 5 |
7063A2011 🎨 |
Shutter assembly a |
| 6 |
7063A3034 🎨 |
Bottom half metalwork |
7
7063A4037 |
Product sticker
(original, black) |
| 7063A4043 |
Product sticker
(original, white) |
| 7163A4004 |
Product sticker
(Plus, black) |
| 7163A4004-1 |
Product sticker
(Plus, white) |
| 8 |
7063A4020 🎨 |
Shutter blade handle (single) |
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
