Portable Source Four Mini LED Exploded Diagrams
Parts with a 🎨 can have a suffix added for different colours. For example:
7063A3006         yoke (black)
7063A3006-1    yoke (white)
7063A3006-5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Source Four Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
No Part Number Description
1 7063A3006  🎨 Yoke (bare) a
2 HWM1652 Screw M3.5 x 6mm
3 HWM1688 Screw M5 x 16mm
4 See breakdown Driver box
5 See breakdown Burner assembly
6 7191A4003 ðŸŽ¨ Shutter barrel knob
7 See breakdown Shutter barrel
8 7063A2010 ðŸŽ¨ Gobo holder
9 HWM305 Screw M3 x 8mm
10 HW4216 Flat washer
11 7192A4012 ðŸŽ¨ Tilt lock knob
a Bare painted yoke not including labels. Not all labels can be ordered
Driver box
 Complete driver boxes
240V with Schuko plug 7063A2203 ðŸŽ¨
240V with UK plug 7063A2205 ðŸŽ¨
120V with Edison plug 7063A2016 ðŸŽ¨
120V with no plug (OEM, bare ends) 7063A2032 ðŸŽ¨
Note: complete driver box comes with a pre-wired mains cable, but the LED output wiring of the existing fixture must be wired in, using the included strain relief. See also Repair Guide
Driver box components
12 7063A4032 ðŸŽ¨ Driver box top cover
13 HW6759 LED output strain relief
14 HWM304 Screw M3 x 6mm
15 7063A4031 ðŸŽ¨ Driver box bottom cover
16 HW6760 Mains input strain relief
17  7063B5601 LED driver (120V)
7063B5601 LED driver (240V)
18 HWM10068 Screw M3.5 x 6mm Nylon
  M7376 Schuko mains cable to bare ends (6.5 ft)
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
Burner assembly components
1 7063A4030 Glider piece
2 7063A3023 Bracket 2
3 HWM304 Screw M3 x 6mm
4 7191A3062 Lens retainer spring
5 7063A4091 Reflector lens
6 7063A3066 Reflector
7 7063A4065 Reflector shim
8 7063A3045 ðŸŽ¨ Housing metalwork
10 7063A4092 COB holder insulator
11 7063B7019 COB holder 10" wires a
7063B7020 COB holder 14" wires a
7163B7119 COB holder 17" wires a
12
CR669-F LED 2700K Gallery
CR682-F LED 3000K
CR670-F LED 3000K Gallery
CR684-F LED 4000K
CR673-F LED 5000K
13 7063A4090 COB thermal pad
14 7063A3044 ðŸŽ¨ Rear end/heatsink
15 HWM1011 Screw M3 x 12mm
16 7063A3046 ðŸŽ¨ Strain relief
17 HWM2105 Screw M3 x 10mm
18 W6470 ðŸŽ¨ Fibreglass sleeve
(order 1 foot per fixture and snip)
19
7063A4083 ðŸŽ¨ Handle label Gallery b
7063A4059 ðŸŽ¨ Handle label 3000K c
7063A4078 ðŸŽ¨ Handle label 4000K
7063A4079 ðŸŽ¨ Handle label 5000K
20 7063A4054 ðŸŽ¨ Rear handle
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
 Complete shutter barrels
Original (non-Plus) 7063A2000 ðŸŽ¨
Source 4 Mini Plus 7163A2000 ðŸŽ¨
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
1 HWM1142 Screw M3 x 6mm
(slot cover)
2 7063A3019 ðŸŽ¨ Gobo slot cover
3 HWM1684 Screw M3.5 x 14mm
4 7063A3033 ðŸŽ¨ Top half metalwork
5 7063A2011 ðŸŽ¨ Shutter assembly a
6 7063A3034 ðŸŽ¨ Bottom half metalwork
7
7063A4037 Product sticker
(original, black)
7063A4043 Product sticker
(original, white)
7163A4004 Product sticker
(Plus, black)
7163A4004-1 Product sticker
(Plus, white)
8 7063A4020 ðŸŽ¨ Shutter blade handle (single)
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
COB Conversion Kit
If your Source 4 Mini LED was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
COB Conversion Kit (excluding LED) 7063K1015
Conversion kit contains the parts shown on the left, plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
CR682-F LED 3000K
CR684-F LED 4000K
CR673-F LED 5000K
