Ion Xe (Win 7) Exploded Diagrams
Because Ion Xe shares many parts between Xe and Xe 20, and between Windows 7 and 10 hardware, the pictures may not match your console exactly, but the part numbers are correct
Bottom tray (Win 7)
No Part Number Description
1 B1073 CPU Fansink
2 M8305 Motherboard I/O Shield
3 4311A4016 Motherboard Label (Win 7)
4 M8309 CPU
5 M8197-F SSD a
6 M8290-F RAM
1 stick per console
7 Contact ETC   Intelligent Power Board b
8 HWM1683 Screw M3x6mm
9 HW7462 Motherboard Stiffener
10 4311B5603 DMX - I/O PCB b
11 HWM1133 XLR Screw
12 M8305 Motherboard
13 HWM1671 M3.5 x .6 x 6mm
icons8-no-camera.png 4350K1007 Windows 7 re-image stick
a Blank SSD, must be imaged after installation
The currently shipping versions of these PCBs require Eos v3.1.4 or higher
PSU, rear of bottom tray, feet
15 4311K1030 Power Supply Kit
16 HW196 Nut 4-40 1/4 1/8
17 HWM1151 Nut M4x0.7
18 HW745 Cable tie mount
19 HW6196 Foot
20 HWM1802 Foot screw
M4 x 12mm
21 4311A3002 Bottom panel, painted, no stickers
22 4310B7004 Gooseneck 3-pin XLR (inc. wiring and PCB connector)
23 HWM1169 Screw M3 x 5mm
24 HW5100 Remote trigger port screw/standoff
25 4310B8001 Remote trigger port (inc. ribbon cable and PCB connector)
26 F210 Power fuse
27 S876 Power connector assembly
Encoders
28 4311A4012 Encoder knob button
29 4390A3006 Encoder knob
30 HW5836 Encoder washer
31 4390A4003 Encoder knob wear surface
32 4311B7004 Power button (inc. wiring,PCB connector, and hex nut)
33 4311A4013 Encoder knob retention plate
34 HWM1831 Screw M2.5 X 6mm
35 4240B5622 Encoder PCB
36 HWM1683 Screw M3 x 6mm
icons8-no-camera.png L1145-F Individual encoder (requires soldering)
Level and rate wheels
Both wheels use identical parts
37 4240A3073 Wheel mount
38 HW5824 Level wheel washer
39 4240A3028 Level/rate wheel
40 4240A4009 Optical encoder sticker
41 4240A3086 Wheel shaft
42 HW7386 Wave spring
43 HWM1799 Screw M3 x 6mm
44 HWM1610 Nut M3 x 0.3
45 4240B5634 Level wheel PCB
46 4370A3053 Level wheel bracket
Face panel PCBs
47 4311B5602 Front USB PCB
48 4390B5603 6x2 button assembly PCB
49 4250B5638 Playback PCB assembly c
50 4390B5611 Main button PCB assembly c
Face panel key and fader caps
51 4110A4036 Fader cap
Xe 20 only
52 4390A2007 Playback MASTER key
53 4390K1020 Main facepanel keys
54 4450K1103 Num-pad, Shift, At, Enter keys
55 4450K1105 Go and Stop keys
56 4240A4044 Playback fader cap
57 4450A2031 Fader bump keys
Xe 20 only
Set of 10 keycaps / 5 faders' worth
 See also this article about different keycaps sets
Cover screws, labels, wireless (Xe)
61 HWM1169 Screw M3 x 5mm
62 Factory Replacement Only
Why?
Product label
63 N1120 WiFi/Bluetooth Antenna
(Win 10 only)
64 4311A4035 FCC label
(Win 10 only)
65 4311A4010 I/O label
66 4311A4020 "Do not remove 4 screws" label
Wrist rest
81 4240A4138 Wheel thumb rest
82 HWM1802 Screw M4 x 16mm
83 HWM1659 Screw M4 x 8mm
84 4240A3174 a Wrist rest
Ion Xe
  4311A3120 a Wrist rest
Ion Xe 20
 a Wrist rest only, held on by HWM1659 screws (not pictured), for other parts contact ETC
Other part numbers not shown in diagrams
BT161 CR2032W battery with wires and connector
More information
4250K1049 Battery holder with wires and connector (bring your own CR2032)
More information
Z1458-F DMX transceiver chip
M7400 DisplayPort to DVI adapter (active)
