ColorSource Fresnel V (Max) Exploded Diagrams
ColorSource Fresnel V and Fresnel V Max share most of their parts in common.
Parts that differ are called out with and Max respectively
Both are available in a non-Multiverse version, these differences are also noted below
Parts with a 🎨 can have a suffix added for different colours. For example:
7417A3018         yoke (black)
7417A3018-1    yoke (white)
7417A3018-5    yoke (silver)
No Part Number Description
1 7417A3018 ðŸŽ¨ Yoke (bare)
2 HWM1971 Screw M4 x 12mm
3 HWM1984 Screw M5 x 10mm
4 7470A3019 Clutch plate
5 7470A2001 Encoder knob cap
6 HWM2228 Bolt M8 x 18mm
7 HW522 Washer, flat, 1/4"
8 HW8144  ðŸŽ¨ Tilt lock knob
9 HW6129
(Non-Multiverse)
Antenna hole blanking grommet
10 HW5125 Bolt 5/16"
11 N1084
(w/ Multiverse)
Multiverse antenna
12 7417A3002 ðŸŽ¨ Upper housing
13 HWM10086 Screw M3 x 4mm
14 7417A3023 Blocker plate
15 HWM1950 Screw M4 x 8mm
16 7417A3025 Gel clip
17 HW750 Spring 0.5"
18 HWM10023 Screw M3 x 8mm
  7417K1010 Gel clip kit
Contains parts 16, 17, 18
19 HWM1853 Screw M3 x 6mm
20 7417A3007 Lens support rod
21 HWM1690 Washer, flat, M3
22 7060A4012 Lens support pad
23 7417A4005 Front glass
24 HWM1745 Screw M3 x 6mm
25 7417A4009 Lens dampener
26 7460A4043 Fresnel lens
27 7417A3017 Lens holder
28 7417A4001 Lens slider
29 HWM6042 Bushing (plastic)
30 HWM1853 Screw M3 x 6mm
31 2500A3013 Belt clamp
32 7417A3008 Belt carriage
33 HWM979 Zoom belt
91 7417A4008 Lens clamp
34 HWM1853 Screw M3 x 6mm
35 HWM1794 (V)
HWM1950 (Max)
Screw M4 x 6mm
Screw M4 x 8mm
36 7417A3105 Motor mount
37 B2142 Zoom motor
38 HWM6029 Snap ring 5mm
39 2500A2022 Belt drive pulley
40 2500A3127 Idler shaft 5mm
41 HWM1855 Screw M4 x 10mm
42 7417A3010 Tension spring bracket
43 HW7499 Spring 1"
44 HWM1656 Nut M5
48 HWM1745 (V)
HWM1546 (Max)
Screw M3 x 6mm
Screw M3 x 8mm
49 7417A4014 Light blocker plate
50 HWM10023 Screw M3 x 8mm
51 HWM1950 Screw M4 x 8mm
52 HWM2108 Screw M3 x 10mm
53 See next section AC power input
54 HWM1151 Nut M4
55 J2525
V - all
Max - ETL only
Power assembly bracket
56 J2513
V - all
Max - ETL only
Power In/Thru Assembly
57 7417B5608
Max CE only
AC input assembly
58 HWM1151 Nut M4
59 7417B2001 Fan + harness
60 7417A3001 ðŸŽ¨ Lower housing
61 HWM10023 Screw M3 x 8mm
62 2510B5609 Sensor
63 7417A3014 Fan bracket
64 HWM1546 Screw M3 x 8mm
65 7417A3015 Fan baffle
66 7417A3103 Heatsink
67 7417A3122 Heatsink bracket
68 HWM1854 Screw M4 x 8mm
69 Kit, see below LED Array
70 HWM1546 Screw M3 x 8mm
71 7417A3104 (V)
7417A3026 (Max)
Mixing tube half
(2 per fixture)
72 7417A4003 (V)
7417A4017 (Max)
Reflector half
(2 per fixture)
73 7417A4004 (V)
7417A4018 (Max)
Lens holder half
(2 per fixture)
74 7417A4015 Spiral tandem lens
75 7417A3012 PSU Tray
76 HWM10062 Screw M3 x 5mm
77 HWM1893 Screw M4 x 4mm
78 FL158
(non-Max CE only)
Line filter
79 PS534 Power supply
80 7417A3013 Control card tray
81 N1111 Antenna mount
82 7417A3016 Rear UI panel
83 HWM1133 Screw M2.9 x 12mm
84 7417A4010 (V) ðŸŽ¨
7417A4022 (Max) ðŸŽ¨
UI overlay
85 7462B5609 NFC PCB
86 7417B5605 User Interface PCB
87 HWM304 Screw M3 x 6mm
88 Kit, see below Control card
89 HW6782 Plastic bushing
90 HWM1151 Nut M4
Control card and array kits
Array calibration is held on the control card, so array and control card must always be replaced as a pair from the same kit
Each kit contains the array, control card, the thermal pads for each of these, and some spare screws. Re-use existing screws and wiring harnesses
-x.x.x represents the firmware version pre-installed on the control card. Contact your dealer or ETC office to see which version is currently shipping
Fresnel V w/ Multiverse 7417K1002-x.x.x
Fresnel V w/o Multiverse 7417K1003-x.x.x
Fresnel V Max w/ Multiverse 7417K1004-x.x.x
Fresnel V Max w/o Multiverse 7417K1005-x.x.x
Yoke labels
Fresnel V
Fresnel V Max
🎨 All labels available in black or white (add -1)
Fresnel V
91
Factory Replacement Only
Regulatory label 1 (all units)
92 7417A4013 QR code label (all units)
93 Service Center Replacement Only FCC label (units with Multiverse only)
Service Center Replacement Only FCC label (units w/o Multiverse only)
Fresnel V Max
95
Requires Factory Replacement
Regulatory label (ETL)
Service Center Replacement Only Regulatory label (CE)
96
Regulatory label (all units)
97 7417A4013 QR code label (all units)
