ColorSource Par Exploded Diagrams
The 3 variants of ColorSource Par (Regular, Deep Blue and Pearl) share most of their parts in common. Differences are called out below
Parts with a 🎨 can have a suffix added for different colours. For example:
7412A3008 yoke (black)
7412A3008-1 yoke (white)
7412A3008-5 yoke (silver)
Yoke and outer body
a This fixture doesn't use yoke stickers b Units manufactured before 2017 may have metric-threaded tilt lock handles and bolts. These are no longer available. Replace both parts if needed. The washer is unchanged |
Body Shell
c The heads and exact lengths of these screws have varied, but the threads have always been M4. The listed screws have Torx 20 heads and can be used with fixtures of any age |
Front/array assembly
Control card & PSU assembly
Control card and array kitsArray calibration is held on the control card, so array and control card must always be replaced as a pair from the same kit Each kit contains the array, control card, thermal pads, and some spare screws. Re-use existing screws and wiring harnesses ⚠️ - when replacing the control card, if you currently have a 3-wire fan (12V), you'll also need to order a new fan. Contact ETC tech service |
Kits may have different firmware versions loaded. Ask your ETC office or dealer which version is current and/or in stock in your region. Contact ETC tech service if you require an RJ45 variant |
Other parts not shown on diagrams
Contact ETC tech service for any other parts, including wiring not listed here |
