ColorSource Par V Zoom Common Spares
This article is intended to complement the exploded diagrams article, providing a quick reference to the most commonly requested spare parts
Component Part Number Notes
Control card & array kit
7421K1004-x.x.x With Multiverse
7421K1005-x.x.x  Without Multiverse
Choose the kit that matches your fixture type (with or without Multiverse).
The control card and array must always be replaced as a pair from the same kit
-x.x.x represents the firmware version pre-installed on the control card. Contact your dealer or ETC office to see which version is currently shipping
 Power supply PS496
Fan
7417B2001
 Body enclosure left 7421A3001  Left and right as seen from behind the fixture with gel clip at top
Body enclosure right  7421A3002  Left and right as seen from behind the fixture with gel clip at top
Does not include clutch plate
Control card switch (up/down/mode) S621-F Requires soldering
Control card DMX in connector (male) J61122-F Requires soldering
Control card DMX thru connector (female) J61121-F Requires soldering
