ColorSource Spot V Exploded Diagrams
Parts with a 🎨 can have a suffix added for different colours. For example:
7460A3011         yoke (black)
7460A3011-1    yoke (white)
7460A3011-5    yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Barrel screws
No Part Number Description US EU UK
1 HW5832 Top barrel screw
2 7060A4008-01 Bottom barrel thumb screw
Yoke
3 HW8144 ðŸŽ¨ Tilt lock handle
4 HW5193 Yoke bolt 5-16
5 HW5126 Flat washer 5-16
6 HW5125 Tilt lock bolt 5-16
7 7460A3011  🎨 Yoke (bare)
  a Bare painted yoke not including stickers. See stickers section below to restore a yoke to factory condition
Top casing
8 HWM1950 Screw M4 x 8mm
9 7060A4010 Bushing gate
10 7413A3004 Barrel rotation clip
11 HWM10017 Screw M4 x 20mm
12 7423A3003 ðŸŽ¨ Upper housing
13 HWM1948 Screw M4 x 10mm
14 7413A3010 ðŸŽ¨ Safety bond loop
Control card mounting
25 7413A3005 Screw clamp
16 HWM1949 Screw M4 x 16mm (mixing tube)
17 Kit, see below Control card
18 HWM1671 Screw M3.5 for control card
4 included in kit
19 HWM1971 Screw M4 x 12mm (heatsink)
20 7423A4005 Rear label sticker
21 7423A4001 NFC & antenna holder
22 7423B5603 NFC PCB
23 HWM1133 Screw M2.9 x 12mm Plastite (XLR mounts)
24 N1129 Multiverse antenna mount & wire
25 N1084 Multiverse antenna
26 HW1253 Screw 4-20 x 5/16 Plastite (holds NFC holder to grille)
27 7413A3008 ðŸŽ¨ Rear grille
28 HW196 Nut 4-40
PSU and bottom casing
29 HWM10062 Screw M3 x 5mm
30 7423A3001 PSU tray
31 HWM1950 Screw M4 x 8mm
32 PS539 Power supply
33 J2525 Power connector bracket
34 J2513 Power connector in/thru assembly (True1)
35 HWM2108 Screw M3 x 10mm
36 HWM1984 Screw M5 x 10mm
37 7470A3019 Clutch plate
38 7423A3002 ðŸŽ¨ Bottom housing
39 7413A3004 Barrel rotation clip
40 7060A4010 Bushing gate
Array, optics and fan
41 7413A2002 Mixing tube
42 HWM1663 M4 Screw
43 HWM1668 M4 Washer
44 7460A3081 Lens spring retainer
45 7460A4061 Glass primary optic
46 7460A4062 Glass optic holder
47 HWM2235 M3 Screw for array
4 included in kit
48 Kit, see below Array PCB
49 7413A3003 Heat sink
50 HWM1609 M5 Screw for fan (4 total)
51 7413A3007 Array frame
52 7423B2001 Fan
Control card and array kits
Array calibration is held on the control card, so array and control card must always be replaced as a pair from the same kit
Each kit contains the array, control card, thermal pads, and some spare screws. Re-use existing screws and wiring harnesses
With Multiverse 7423K1003-x.x.x
Without Multiverse 7423K1004-x.x.x
-x.x.x represents the firmware version pre-installed on the control card. Contact your dealer or ETC office to see which version is currently shipping
Yoke Labels
Coming soon!
🎨 All labels available in black or white (add -1)
