F-Drive Portable Irideon FPZ Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7191A3049 yoke (black)
7191A3049 -1 yoke (white)
7191A3049 -5 yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon FPZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
| 1 |
7148A4073 🎨 |
F-Drive box bottom housing |
| 2 |
7148B5635 |
F-Drive PCB |
| 3 |
7184A4072 🎨 |
F-Drive box top housing |
| 4 |
HWM1611 |
Screw M4 x 8mm |
| 5 |
HW6758 |
Strain relief |
| 6 |
7191A2000 |
Gobo holder |
| 7 |
See breakdown |
Shutter gate |
| 8 |
See breakdown |
Lens tube |
| 9 |
HWM1812 |
Screw M3 x 30mm |
| 10 |
See breakdown |
Fixture body |
| 11 |
HWM1029 |
Screw M4 x 8mm |
Fixture body
Fixture body components
| No |
Part Number |
Description |
| 1 |
7191A3035 🎨 |
Rear housing cap |
| 2 |
7191A3029 |
Strain relief bracket |
| 3 |
HWM1142 |
Screw M3 x 6mm |
| 4 |
HW6758 |
Strain relief grip |
| 5 |
HW9498 |
Clip fastener |
| 6 |
HW9497 |
Stud fastener |
| 7 |
HWM1670 |
Screw M3 x 10mm |
| 8 |
7191A3032 🎨 |
LED housing |
| 9 |
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 10 |
7191A4044 |
COB holder insulator |
| 11 |
7191A4043 |
COB holder thermal pad |
| 12 |
7191B2002 |
COB holder |
| 13 |
7191A3002 🎨 |
Yoke bolt |
| 14 |
HW4251 |
Flat washer |
| 15 |
7191A4010 🎨 |
Yoke degree angle label |
| 16 |
7191A3034 🎨 |
Reflector housing |
| 17 |
HWM1809 |
Set screw M4 x 12mm |
| 18 |
HW469 (black)
HW487 (white) |
Flat washer nylon |
| 19 |
7192A4012 🎨 |
Yoke knob |
| 20 |
7191A3049 🎨 |
Yoke (bare) a |
| 21 |
HW6906 |
Bushing
(portable only) |
| 22 |
7191A4040 |
Reflector |
| 23 |
7191A4042 |
Lens |
| 24 |
7191A3062 |
Lens retainer spring |
| 25 |
7191A3001 |
Glider mounting bracket |
| 26 |
7063A4030 |
Glider |
| 27 |
HWM3112 |
Screw M3 x 5mm |
a Bare painted yoke not including labels. Not all labels can be ordered
Shutter Gate & Lens Tube
Complete Shutter Gate and Lens Tube
| Part Number |
Item |
| 7191A2001 🎨 |
Complete lens tube |
| 7191A2002 🎨 |
Complete shutter gate |
| HWM1812 |
Screw to assemble lens tube and shutter gate (2 required) |
Shutter gate components
| No |
Part Number |
Description |
| 1 |
HWM1817 |
Screw M2 x 8mm |
| 2 |
HWM1808 |
Screw M3 x 16mm |
| 3 |
7191A3009 |
Rotating gate bracket |
| 4 |
7191A3017 |
Locking key |
| 5 |
7191A3036 🎨 |
Rear housing |
| 6 |
HWM1142 |
Screw M3 x 6mm |
| 7 |
7191A3015 |
Locking plate |
| 8 |
7191A3014 |
Clamping disc |
| 9 |
7191A3025 |
Spring plate |
| 10 |
7063A3009 |
Gate plate |
| 11 |
7191A3020 |
Gate shim |
| 12 |
7063A2009 🎨 |
Shutter blade
(including handle) |
7063A4020 🎨 |
Shutter blade handle |
| 13 |
7063A3008 |
Divider plate |
| 14 |
7191A3013 |
Clamping plate |
| 15 |
7191A3037 🎨 |
Front housing |
| 16 |
7191A4004 🎨 |
Gobo cover |
Lens tube components
| No |
Part Number |
Description |
| 17 |
Contact ETC 🎨 |
Media holder |
| 18 |
HWM1148 |
Screw M2.4 x 5mm |
| 19 |
Contact ETC |
Magnet |
| 20 |
7191A4007 |
Silicone pad |
| 21 |
HWM2108 |
Screw M3 x 10mm |
| 22 |
Contact ETC🎨 |
Media holder bracket |
| 23 |
7191A4009 |
Zoom angle sticker |
| 24 |
7191A4003 🎨 |
Zoom lens knob |
| 25 |
7191A3033 🎨 |
Lens tube body |
| 26 |
7191A4001 |
Front lens holder 63mm |
| 27 |
7063A4076 |
Front lens 63mm |
| 28 |
7063A4077 |
Rear lens 40mm |
| 29 |
7191A3006 |
Light blocker bracket |
| 30 |
7191A4000 |
Rear lens holder 40mm |
| 31 |
7191A3005 |
Rear bracket |
