Mains Canopy Irideon FPZ Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7191A3049 yoke (black)
7191A3049 -1 yoke (white)
7191A3049 -5 yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon FPZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
Canopy Driver Assembly (DMX)
Driver box components
| No |
Part Number |
Description |
| 1 |
7191A3051 |
Top bracket |
| 2 |
7411A4010 |
AC input label |
| 3 |
J3895 |
Terminal block |
| 4 |
HWM1142 |
Screw M3 x 6mm |
| 5 |
7191A3030 |
Standoff M3 x 0.25" |
| 6 |
7191B5613 |
Driver PCB - original |
| 7191B5713 |
Driver PCB - Plus |
| 7 |
HWM1832 |
Screw M2.5 x 6mm |
| 8 |
HWM1843 |
Standoff M2.5 x 7mm |
| 9 |
HWM3112 |
Screw M3 x 5mm |
| 10 |
PS444 |
Power supply - original
(pictured) |
| 7191B5712 |
Power supply - Plus
(original pictured) |
| 11 |
7191A3047 |
Strain relief retainer |
| 12 |
HW6758 |
Strain relief |
| 13 |
HWM1151 |
Nut M4 |
| 14 |
7191A3054 |
Nipple cap |
| 15 |
HWM1767 |
Screw M4 x 8mm |
| 16 |
I2170 |
Label Prop 65 (EN/FR) |
| 17 |
7191A3048 |
Yoke bushing |
| 18 |
7191A3046 |
Hanging bracket |
| 19 |
7410B5918 |
DMX termination PCB a |
| 20 |
HWM1025 |
Screw M3 x 16mm |
| 21 |
7411A4012 |
Label DMX in |
| 22 |
7411A4013 |
Label DMX thru |
| 23 |
7411A4011 |
Label DMX and termination |
| 24 |
7191A4018 🎨 |
Canopy housing |
a All DMX PCBs come with blue "CUI" connectors. If your existing fixture uses orange Weidmuller connectors, order new CUI termination kits
Canopy Driver Assembly (DALI / 0-10V)
| No |
Part Number |
Description |
| 1 |
7191A3050 |
Top bracket |
| 2 |
HWM1150 |
Screw M5.8 x 6mm |
| 3 |
HW4109 |
Star washer |
| 4 |
PS460 |
Power supply (DALI) |
| PS461 |
Power supply (0-10V) |
| 5 |
HWM3112 |
Screw M3 x 5mm |
| 6 |
7191A3047 |
| 7 |
HW6758 |
Strain relief |
| 8 |
HWM1151 |
Nut M4 |
| 9 |
7191A3054 |
Nipple cap |
| 10 |
7191A3048 |
Yoke bushing |
| 11 |
HWM1767 |
Screw M4 x 8mm |
| 12 |
7191A3046 |
Hanging bracket |
| 13 |
I2170 |
| 14 |
7191A4018 🎨 |
Canopy housing |
Fixture body
Fixture body components
| No |
Part Number |
Description |
| 1 |
7191A3035 🎨 |
Rear housing cap |
| 2 |
7191A3029 |
Strain relief bracket |
| 3 |
HWM1142 |
Screw M3 x 6mm |
| 4 |
HW6758 |
Strain relief grip |
| 5 |
HW9498 |
Clip fastener |
| 6 |
HW9497 |
Stud fastener |
| 7 |
HWM1670 |
Screw M3 x 10mm |
| 8 |
7191A3032 🎨 |
LED housing |
| 9 |
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 10 |
7191A4044 |
COB holder insulator |
| 11 |
7191A4043 |
COB holder thermal pad |
| 12 |
7191B2002 |
COB holder |
| 13 |
7191A3002 🎨 |
Yoke bolt |
| 14 |
HW4251 |
Flat washer |
| 15 |
7191A4010 🎨 |
Yoke degree angle label |
| 16 |
7191A3034 🎨 |
Reflector housing |
| 17 |
HWM1809 |
Set screw M4 x 12mm |
| 18 |
HW469 (black)
HW487 (white) |
Flat washer nylon |
| 19 |
7192A4012 🎨 |
Yoke knob |
| 20 |
7191A3049 🎨 |
Yoke (bare) a |
| 21 |
HW6906 |
Bushing
(portable only) |
| 22 |
7191A4040 |
Reflector |
| 23 |
7191A4042 |
Lens |
| 24 |
7191A3062 |
Lens retainer spring |
| 25 |
7191A3001 |
Glider mounting bracket |
| 26 |
7063A4030 |
Glider |
| 27 |
HWM3112 |
Screw M3 x 5mm |
a Bare painted yoke not including labels. Not all labels can be ordered
Important: If your LED chip doesn't look like the one in the diagram, see COB Conversion Kit below
Shutter Gate & Lens Tube
Complete Shutter Gate and Lens Tube
| Part Number |
Item |
| 7191A2001 🎨 |
Complete lens tube |
| 7191A2002 🎨 |
Complete shutter gate |
| HWM1812 |
Screw to assemble lens tube and shutter gate (2 required) |
Shutter gate components
| No |
Part Number |
Description |
| 1 |
HWM1817 |
Screw M2 x 8mm |
| 2 |
HWM1808 |
Screw M3 x 16mm |
| 3 |
7191A3009 |
Rotating gate bracket |
| 4 |
7191A3017 |
Locking key |
| 5 |
7191A3036 🎨 |
Rear housing |
| 6 |
HWM1142 |
Screw M3 x 6mm |
| 7 |
7191A3015 |
Locking plate |
| 8 |
7191A3014 |
Clamping disc |
| 9 |
7191A3025 |
Spring plate |
| 10 |
7063A3009 |
Gate plate |
| 11 |
7191A3020 |
Gate shim |
| 12 |
7063A2009 🎨 |
Shutter blade
(including handle) |
7063A4020 🎨 |
Shutter blade handle |
| 13 |
7063A3008 |
Divider plate |
| 14 |
7191A3013 |
Clamping plate |
| 15 |
7191A3037 🎨 |
Front housing |
| 16 |
7191A4004 🎨 |
Gobo cover |
Lens tube components
| No |
Part Number |
Description |
| 17 |
Contact ETC 🎨 |
Media holder |
| 18 |
HWM1148 |
Screw M2.4 x 5mm |
| 19 |
Contact ETC |
Magnet |
| 20 |
7191A4007 |
Silicone pad |
| 21 |
HWM2108 |
Screw M3 x 10mm |
| 22 |
Contact ETC🎨 |
Media holder bracket |
| 23 |
7191A4009 |
Zoom angle sticker |
| 24 |
7191A4003 🎨 |
Zoom lens knob |
| 25 |
7191A3033 🎨 |
Lens tube body |
| 26 |
7191A4001 |
Front lens holder 63mm |
| 27 |
7063A4076 |
Front lens 63mm |
| 28 |
7063A4077 |
Rear lens 40mm |
| 29 |
7191A3006 |
Light blocker bracket |
| 30 |
7191A4000 |
Rear lens holder 40mm |
| 31 |
7191A3005 |
Rear bracket |
COB Conversion Kit
If your Irideon FPZ was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
| COB Conversion Kit (excluding LED) |
7191K1015 |
Conversion kit contains the parts shown on the left (COB holder parts, new reflector, lens, and holder), plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
| Part Number |
Description |
| CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
