Portable Irideon FPZ Exploded Diagrams
Parts with a  🎨 can have a suffix added for different colours. For example:
7191A3049          yoke (black)
7191A3049 -1    yoke (white)
7191A3049 -5    yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon FPZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
No Part Number Description
1 7191A3043 Support washer
2 M7412 RJ45 blind plug
(qty 2)
3 Factory Replacement Only
Why?
Driver box sticker
4 HWM1611 Screw M4 x 8mm
5 See breakdown Driver box
6 7191A2000 Gobo holder
7 See breakdown Shutter gate
8 See breakdown Lens tube
9 HWM1812 Screw M3 x 30mm
10 See breakdown Fixture body
Driver Box
Driver box components
1 7191A4114 ðŸŽ¨ Driver box housing top
2 HW2340 Screw 6/32 x 3/8" Taptite
3 7191A4011 ðŸŽ¨ Control knob cap
4 HWM1832 Screw M2.5 x 6mm
5 7191B5603-CFG LED driver PCB - original
7191B5703-CFG LED driver PCB - Plus
6 PS444 Power supply - original
(pictured)
7191B5612 Power supply - Plus
(original pictured)
7 HW6758 Strain relief - LED output
8 7191A4115 ðŸŽ¨ Driver box housing bottom
9 HW6760 Strain relief - mains input
(qty 2)
Fixture body
Fixture body components
1 7191A3035 ðŸŽ¨ Rear housing cap
2 7191A3029 Strain relief bracket
3 HWM1142 Screw M3 x 6mm
4 HW6758 Strain relief grip
5 HW9498 Clip fastener
6 HW9497 Stud fastener
7 HWM1670 Screw M3 x 10mm
8 7191A3032 ðŸŽ¨ LED housing
9 CR669-F LED 2700K Gallery
CR682-F LED 3000K
CR670-F LED 3000K Gallery
CR684-F LED 4000K
CR673-F LED 5000K
10 7191A4044 COB holder insulator
11 7191A4043 COB holder thermal pad
12 7191B2002 COB holder
13 7191A3002 ðŸŽ¨ Yoke bolt
14 HW4251 Flat washer
15 7191A4010 ðŸŽ¨ Yoke degree angle label
16 7191A3034 ðŸŽ¨ Reflector housing
17 HWM1809 Set screw M4 x 12mm
18 HW469 (black)
HW487 (white)
Flat washer nylon
19 7192A4012 ðŸŽ¨ Yoke knob
20 7191A3049 ðŸŽ¨ Yoke (bare) a
21 HW6906 Bushing
(portable only)
22 7191A4040 Reflector
23 7191A4042 Lens
24 7191A3062 Lens retainer spring
25 7191A3001 Glider mounting bracket
26 7063A4030 Glider
27 HWM3112 Screw M3 x 5mm
a Bare painted yoke not including labels. Not all labels can be ordered
Important: If your LED chip doesn't look like the one in the diagram, see COB Conversion Kit below
Shutter Gate & Lens Tube
 Complete Shutter Gate and Lens Tube
Part Number Item
7191A2001 ðŸŽ¨ Complete lens tube
7191A2002 ðŸŽ¨ Complete shutter gate
HWM1812 Screw to assemble lens tube and shutter gate (2 required)
Shutter gate components
1 HWM1817 Screw M2 x 8mm
2 HWM1808 Screw M3 x 16mm
3 7191A3009 Rotating gate bracket
4 7191A3017 Locking key
5 7191A3036 ðŸŽ¨ Rear housing
6 HWM1142 Screw M3 x 6mm
7 7191A3015 Locking plate
8 7191A3014 Clamping disc
9 7191A3025 Spring plate
10 7063A3009 Gate plate
11 7191A3020 Gate shim
12 7063A2009 ðŸŽ¨ Shutter blade
(including handle)
  7063A4020 ðŸŽ¨ Shutter blade handle
13 7063A3008 Divider plate
14 7191A3013 Clamping plate
15 7191A3037 ðŸŽ¨ Front housing
16 7191A4004 ðŸŽ¨ Gobo cover
FPZ Lens Tube Exploded.jpg Lens tube components
17 Contact ETC ðŸŽ¨ Media holder
18 HWM1148 Screw M2.4 x 5mm
19 Contact ETC Magnet
20 7191A4007 Silicone pad
21 HWM2108 Screw M3 x 10mm
22 Contact ETC🎨 Media holder bracket
23 7191A4009 Zoom angle sticker
24 7191A4003 🎨 Zoom lens knob
25 7191A3033 🎨 Lens tube body
26 7191A4001 Front lens holder 63mm
27 7063A4076 Front lens 63mm
28 7063A4077 Rear lens 40mm
29 7191A3006 Light blocker bracket
30 7191A4000 Rear lens holder 40mm
31 7191A3005 Rear bracket
COB Conversion Kit
If your Irideon FPZ was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
COB Conversion Kit (excluding LED) 7191K1015
Conversion kit contains the parts shown on the left (COB holder parts, new reflector, lens, and holder), plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
CR682-F LED 3000K
CR684-F LED 4000K
CR673-F LED 5000K
