Mains Canopy Irideon WLZ Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7191A3049 yoke (black)
7191A3049 -1 yoke (white)
7191A3049 -5 yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Irideon WLZ comes in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
| 1 |
7191A3052 |
Canopy plate |
| 2 |
HWM1151 |
Nut M4 |
| 3 |
See breakdown (DMX)
See breakdown (DALI / 0-10V)
Canopy enclosure |
| 4 |
7191A4019 🎨 |
Screw plug cap |
| 5 |
HWM1016 |
Screw M4 x 20mm |
| 6 |
HW5548 |
Flat washer, black nylon |
| 7 |
HW5831 |
Wavy washer? |
| 8 |
7191A3042🎨 |
Yoke bushing nut |
| 9 |
See breakdown |
Fixture body |
Canopy Driver Assembly (DMX)
Driver box components
| No |
Part Number |
Description |
| 1 |
7191A3051 |
Top bracket |
| 2 |
7411A4010 |
AC input label |
| 3 |
J3895 |
Terminal block |
| 4 |
HWM1142 |
Screw M3 x 6mm |
| 5 |
7191A3030 |
Standoff M3 x 0.25" |
| 6 |
7191B5613 |
Driver PCB - original |
| 7191B5713 |
Driver PCB - Plus |
| 7 |
HWM1832 |
Screw M2.5 x 6mm |
| 8 |
HWM1843 |
Standoff M2.5 x 7mm |
| 9 |
HWM3112 |
Screw M3 x 5mm |
| 10 |
PS444 |
Power supply - original
(pictured) |
| 7191B5712 |
Power supply - Plus
(original pictured) |
| 11 |
7191A3047 |
Strain relief retainer |
| 12 |
HW6758 |
Strain relief |
| 13 |
HWM1151 |
Nut M4 |
| 14 |
7191A3054 |
Nipple cap |
| 15 |
HWM1767 |
Screw M4 x 8mm |
| 16 |
I2170 |
Label Prop 65 (EN/FR) |
| 17 |
7191A3048 |
Yoke bushing |
| 18 |
7191A3046 |
Hanging bracket |
| 19 |
7410B5918 |
DMX termination PCB a |
| 20 |
HWM1025 |
Screw M3 x 16mm |
| 21 |
7411A4012 |
Label DMX in |
| 22 |
7411A4013 |
Label DMX thru |
| 23 |
7411A4011 |
Label DMX and termination |
| 24 |
7191A4018 🎨 |
Canopy housing |
a All DMX PCBs come with blue "CUI" connectors. If your existing fixture uses orange Weidmuller connectors, order new CUI termination kits
Canopy Driver Assembly (DALI / 0-10V)
| No |
Part Number |
Description |
| 1 |
7191A3050 |
Top bracket |
| 2 |
HWM1150 |
Screw M5.8 x 6mm |
| 3 |
HW4109 |
Star washer |
| 4 |
PS460 |
Power supply (DALI) |
| PS461 |
Power supply (0-10V) |
| 5 |
HWM3112 |
Screw M3 x 5mm |
| 6 |
7191A3047 |
| 7 |
HW6758 |
Strain relief |
| 8 |
HWM1151 |
Nut M4 |
| 9 |
7191A3054 |
Nipple cap |
| 10 |
7191A3048 |
Yoke bushing |
| 11 |
HWM1767 |
Screw M4 x 8mm |
| 12 |
7191A3046 |
Hanging bracket |
| 13 |
I2170 |
| 14 |
7191A4018 🎨 |
Canopy housing |
Fixture body
| No |
Part Number |
Description |
| 1 |
Contact ETC 🎨 |
Media holder |
| 2 |
7191A4007 |
Silicone pad |
| 3 |
HWM1148 |
Screw M2 x 5mm |
| 4 |
HWM1808 |
Screw M3 x 16mm |
| 5 |
OP2097 |
Fresnel lens |
| 6 |
Contact ETC |
Magnet |
| 7 |
Contact ETC 🎨 |
Front lens mount |
| 8 |
7192A4026 |
Glass plate
CE only |
| 9 |
7192A4027 |
Lens mount ring |
| 10 |
7192A4009 🎨 |
Zoom label left |
| 11 |
HW469 (black)
HW487 (white/silver) |
Flat washer |
| 12 |
7192A4012 🎨 |
Yoke knob |
| 13 |
7191A3049 🎨 |
Yoke (bare) a |
| 14 |
7191A4010 🎨 |
Yoke degree angle label |
| 15 |
7192A4008 🎨 |
Back cap label |
| 16 |
HWM1346 |
Screw M4 x 10mm |
| 17 |
7192A3014 🎨 |
Zoom knob |
| 18 |
HW5861 |
Flat washer |
| 19 |
HW4251 |
Flat washer |
| 20 |
7191A3002 |
Yoke bolt |
| 21 |
7192A4010 🎨 |
Zoom label right |
a Bare painted yoke not including labels. Not all labels can be ordered
| No |
Part Number |
Description |
| 22 |
7192A3012 🎨 |
Main housing |
| 23 |
HWM3112 |
Screw M3 x 5mm |
| 24 |
HWM2108 |
Screw M3 x 10mm |
| 25 |
7192A4024 |
Isolator ring |
| 26 |
7192A3026 |
Heat sink plate |
| 27 |
HWM1670 |
Screw M3 x 10mm |
| 28 |
7192A4000 |
Shaft bearing |
| 29 |
HWM1142 |
Screw M3 x 6mm |
| 30 |
7191A3029 |
Strain relief bracket |
| 31 |
HW6758 |
Strain relief grip |
| 32 |
HWM1149 |
Screw M4 x 6mm |
| 33 |
HWM1551 |
Screw M4 x 16mm |
| 34 |
7192A3013 🎨 |
Rear housing |
| 35 |
7192A2010 |
Shaft assembly |
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
| No |
Part Number |
Description |
| 36 |
HWM1142 |
Screw M3 x 6mm |
| 37 |
7191A4044 |
COB holder insulator |
| 38 |
7191B2001 |
COB holder |
| 39 |
CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
| 40 |
7191A4043 |
COB holder thermal pad |
| 41 |
7192A3017 |
Heat sink/LED mount |
| 42 |
HW5861 |
Flat washer |
| 43 |
7192A3018 |
Threaded rod |
| 44 |
HWM1670 |
Screw M3 x 10mm |
| 45 |
7192A4014 |
Threaded nut mount |
| 46 |
7192A4001 |
Shaft roller a |
| 47 |
7192A3027 |
Shaft roller screw |
a Roller includes small rubber ring. Rings are not available separately, contact ETC for advice if ring is broken or lost
COB Conversion Kit
If your Irideon WLZ was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
| COB Conversion Kit (excluding LED) |
7192K1015 |
Conversion kit contains the parts shown on the left (COB holder parts, plus zoom labels in both black and white, since these need to be removed to access the LED), plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
| Part Number |
Description |
| CR669-F |
LED 2700K Gallery |
| CR682-F |
LED 3000K |
| CR670-F |
LED 3000K Gallery |
| CR684-F |
LED 4000K |
| CR673-F |
LED 5000K |
