F-Drive Portable Source 4 Mini LED Exploded Diagrams
Parts with a 🎨 can have a suffix added for different colours. For example:
7063A3006         yoke (black)
7063A3006-1    yoke (white)
7063A3006-5    yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Source 4 Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
This product was sold as "Source 4 Mini F-Drive Portable" and then "Source 4 Mini Plus F-Drive Portable". These products are identical apart from the label on the yoke, and the label on the shutter barrel (and hence the part number of the complete shutter barrel). We recommend replacing stickered parts like-for-like, but otherwise all parts are the same
Top level components
No Part Number Description US EU UK
1 See breakdown Shutter barrel
2 7063A2010 πŸŽ¨ Gobo holder
3 7192A4012 πŸŽ¨ Tilt lock knob
4 HW4216 Flat washer
5 HWM1611 Screw M4 x 8mm
6
Factory Replacement Only
Product label (Plus)
Product label (original)
7 7063A3006 πŸŽ¨ Yoke (bare) a
8 7191A4003 πŸŽ¨ Shutter barrel knob
9 See breakdown Burner assembly
10 HWM1688 Screw M5 x 16mm
11 7148A4073 πŸŽ¨ F-Drive box bottom housing
12 HW6759 Strain relief
13 7148B5635 F-Drive PCB
14 HWM1029 Screw M4 x 8mm
15 7184A4072 πŸŽ¨ F-Drive box top housing
  a Bare painted yoke not including stickers - the only stickers are part 6 (product label) and the date sticker (cannot be ordered)
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
 Complete burner assemblies
2700K Gallery 7063K1027 πŸŽ¨
3000K 7063K1028 πŸŽ¨
3000K Gallery 7063K1026 πŸŽ¨
4000K 7063K1029 πŸŽ¨
5000K  7063K1030 πŸŽ¨
Note: complete burner assembly comes with the black/red LED wires with bare ends, inside the fibreglass sleeve, ready to be terminated in the driver box. See also Repair Guide
 πŸŽ¨Complete burner assemblies are available in black or white. For other colors, contact ETC tech service
Burner assembly components
1 7063A4030 Glider piece
2 7063A3023 Bracket 2
3 HWM304 Screw M3 x 6mm
4 7191A3062 Lens retainer spring
5 7063A4091 Reflector lens
6 7063A3066 Reflector
7 7063A4065 Reflector shim
8 7063A3045 πŸŽ¨ Housing metalwork
9 HWM305 Screw M3 x 8mm
10 7063A4092 COB holder insulator
11 7063B7019 COB holder 10" wires a
  7063B7020 COB holder 14" wires a
  7163B7119 COB holder 17" wires a
12 CR669-F LED 2700K Gallery
  CR682-F LED 3000K
  CR670-F LED 3000K Gallery
  CR684-F LED 4000K
  CR673-F LED 5000K
13 7063A4090 COB thermal pad
14 7063A3044 πŸŽ¨ Rear end/heatsink
15 HWM1011 Screw M3 x 12mm
16 7063A3046 πŸŽ¨ Strain relief
17 HWM2105 Screw M3 x 10mm
18 W6470 πŸŽ¨ Fibreglass sleeve
(order 1 foot per fixture and snip)
19 7063A4083 πŸŽ¨ Handle label Gallery b
  7063A4059 πŸŽ¨ Handle label 3000K c
  7063A4078 πŸŽ¨ Handle label 4000K
  7063A4079 πŸŽ¨ Handle label 5000K
20 7063A4054 πŸŽ¨ Rear handle
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
 Complete shutter barrels
Original (non-Plus) 7063A2000 πŸŽ¨
Source 4 Mini Plus 7163A2000 πŸŽ¨
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
1 HWM1142 Screw M3 x 6mm
(slot cover)
2 7063A3019 πŸŽ¨ Gobo slot cover
3 HWM1684 Screw M3.5 x 14mm
4 7063A3033 πŸŽ¨ Top half metalwork
5 7063A2011 πŸŽ¨ Shutter assembly a
6 7063A3034 πŸŽ¨ Bottom half metalwork
7 7063A4037 Product sticker
(original, black)
  7063A4043 Product sticker
(original, white)
  7163A4004 Product sticker
(Plus, black)
  7163A4004-1 Product sticker
(Plus, white)
8 7063A4020 πŸŽ¨ Shutter blade handle (single)
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
