Internal Source 4 Mini Source Article for Common Parts Exploded
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below! |
Complete burner assemblies
Note: complete burner assembly comes with the black/red LED wires with bare ends, inside the fibreglass sleeve, ready to be terminated in the driver box. See also Repair Guide Burner assembly components
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip |
Shutter barrel
Complete shutter barrels
Note: original and Plus are functionally identical, but have the correct sticker for the type Shutter barrel components
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed |
COB Conversion Kit
If your Source 4 Mini LED was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead Complete Kit
Conversion kit contains the parts shown on the left, plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process LED Chips
