Mains Canopy Source 4 Mini LED Exploded Diagrams
Parts with a 🎨 can have a suffix added for different colours. For example:
7063A3006         yoke (black)
7063A3006-1    yoke (white)
7063A3006-5    yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Source 4 Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
No Part Number Description US EU UK
7 7063A3006  🎨 Yoke (bare) a
8 HWM1688 Screw M5 x 16mm
1 See breakdown Canopy assembly
10 See breakdown Burner assembly
12 7191A4003  🎨 Shutter barrel knob
11 See breakdown Shutter barrel
9 7063A2010  🎨 Gobo holder
6 HW4216 Flat washer
5 7192A4012  🎨 Tilt lock knob
2 HW5858 Flat washer
3 7063A4098 Retaining washer
("banjo nut")
4 HW5821 Jam nut
  a Bare painted yoke not including stickers. See stickers section below to restore a yoke to factory condition
Canopy assembly
 Complete canopy kits
120V 7063K1007 🎨
240V 7063K1008 🎨
Kit includes all the parts below, plus 3x Wago 2-position wire joiners
Canopy assembly components
13 HW5535 Universal circular mount
14 HW3118 Flat washer
15 HW392 Screw 8/32 x 1/2
16 HW183 Screw 4/40 x 1/4
17 7063A3048 Driver board cover
18 7063B5601 Driver board (120V)
  7063B5701 Driver board (240V)
19 HW375 Nut 8/32 x 1/2
20 7060B7017 Safety wire
21 7063A4061 Insulator
22 HWM10171 Set screw M5 x 8mm
23 7063A4097 Retaining collar
24 7063A3047 Driver board mount
25 4000A4013 Ground symbol sticker
26 7063A3037 🎨 Canopy
27 7063A4098 Retaining washer
("banjo nut") a
28 HW5821 Jam nut a
29 HW3219 Screw 8/32 x 2.5"
a These parts are repeated from the "top level components" view, shown here because they are included in the kit
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
 Complete burner assemblies
2700K Gallery 7063K1027 πŸŽ¨
3000K 7063K1028 πŸŽ¨
3000K Gallery 7063K1026 πŸŽ¨
4000K 7063K1029 πŸŽ¨
5000K  7063K1030 πŸŽ¨
Note: complete burner assembly comes with the black/red LED wires with bare ends, inside the fibreglass sleeve, ready to be terminated in the driver box. See also Repair Guide
 πŸŽ¨Complete burner assemblies are available in black or white. For other colors, contact ETC tech service
Burner assembly components
1 7063A4030 Glider piece
2 7063A3023 Bracket 2
3 HWM304 Screw M3 x 6mm
4 7191A3062 Lens retainer spring
5 7063A4091 Reflector lens
6 7063A3066 Reflector
7 7063A4065 Reflector shim
8 7063A3045 πŸŽ¨ Housing metalwork
9 HWM305 Screw M3 x 8mm
10 7063A4092 COB holder insulator
11 7063B7019 COB holder 10" wires a
  7063B7020 COB holder 14" wires a
  7163B7119 COB holder 17" wires a
12 CR669-F LED 2700K Gallery
  CR682-F LED 3000K
  CR670-F LED 3000K Gallery
  CR684-F LED 4000K
  CR673-F LED 5000K
13 7063A4090 COB thermal pad
14 7063A3044 πŸŽ¨ Rear end/heatsink
15 HWM1011 Screw M3 x 12mm
16 7063A3046 πŸŽ¨ Strain relief
17 HWM2105 Screw M3 x 10mm
18 W6470 πŸŽ¨ Fibreglass sleeve
(order 1 foot per fixture and snip)
19 7063A4083 πŸŽ¨ Handle label Gallery b
  7063A4059 πŸŽ¨ Handle label 3000K c
  7063A4078 πŸŽ¨ Handle label 4000K
  7063A4079 πŸŽ¨ Handle label 5000K
20 7063A4054 πŸŽ¨ Rear handle
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
 Complete shutter barrels
Original (non-Plus) 7063A2000 πŸŽ¨
Source 4 Mini Plus 7163A2000 πŸŽ¨
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
1 HWM1142 Screw M3 x 6mm
(slot cover)
2 7063A3019 πŸŽ¨ Gobo slot cover
3 HWM1684 Screw M3.5 x 14mm
4 7063A3033 πŸŽ¨ Top half metalwork
5 7063A2011 πŸŽ¨ Shutter assembly a
6 7063A3034 πŸŽ¨ Bottom half metalwork
7 7063A4037 Product sticker
(original, black)
  7063A4043 Product sticker
(original, white)
  7163A4004 Product sticker
(Plus, black)
  7163A4004-1 Product sticker
(Plus, white)
8 7063A4020 πŸŽ¨ Shutter blade handle (single)
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
Yoke labels
1 Canopy-specific product label (CE) Service Center Replacement Only
1 Canopy-specific product label (ETL)
Factory Replacement Only
2 Prop 65 label (EN/FR) I2170 🎨
3 Production date label, cannot be ordered N/A
COB Conversion Kit
If your Source 4 Mini LED was manufactured with the old-style LED, mounted on a green-blue PCB, these are no longer available. You will need to use the conversion kit to install the new COB-style LED instead
Complete Kit
COB Conversion Kit (excluding LED) 7063K1015
Conversion kit contains the parts shown on the left, plus 2x butt splices and 2x pieces of heat shrink to attach the COB holder wires to the existing wires from the driver. See also the repair guide for this process
⚠️ The kit does not include an LED, order the correct variant from the list below
LED Chips
CR682-F LED 3000K
CR684-F LED 4000K
CR673-F LED 5000K
