Portable Plus Source 4 Mini LED Exploded Diagrams
- Last updated
Save as PDF
Parts with a π¨ can have a suffix added for different colours. For example:
7163A3000 yoke (black)
7163A3000 -1 yoke (white)
7163A3000 -5 yoke (silver)
NB: plastic parts and stickers are generally available only in black and white
Source 4 Minis come in many different variants, and it is often possible to order either an entire sub-assembly, or the parts within that sub-assembly. The guide below is slightly different to other fixtures to take that fact into account
Top level components
| No |
Part Number |
Description |
US |
EU |
UK |
| 1 |
7191A3043 |
Support washer |
| 2 |
M7412 |
RJ45 blind plug
(qty 2) |
| 3 |
Service Center
Replacement Only
Driver box sticker (CE) |
Factory Replacement Only
Driver box sticker (ETL) |
| 4 |
See breakdown |
Driver box |
| 5 |
7163A3000 π¨ |
Yoke (bare) a |
| 6 |
HWM1169 |
Screw M3.5 x 6mm |
| 7 |
HW6906 |
Bushing |
| 8 |
HWM1688 |
Screw M5 x 16mm |
| 9 |
7192A4012 π¨ |
Tilt lock knob |
| 10 |
HW4216 |
Flat washer |
| 11 |
See breakdown |
Burner assembly |
| 12 |
7063A2010 π¨ |
Gobo holder |
| 13 |
See breakdown |
Shutter barrel |
| 14 |
7191A4003 π¨ |
Shutter barrel knob |
a Bare painted yoke - this version does not use stickers
Driver box
Complete driver boxes
| 240V with Schuko plug |
7163A2042 π¨ |
| 240V with UK plug |
7163A2043 π¨ |
| 120V with Edison plug |
7163A2044 π¨ |
Note: complete driver box comes with a pre-wired mains cable, but the LED output wiring of the existing fixture must be wired in, using the included strain relief. See also Repair Guide
Does not include the legend/product sticker - See part 3 in the "top level assembly" section, CE or ETL as appropriate
Driver box components
| No |
Part Number |
Description |
US |
EU |
UK |
| 15 |
I2170 π¨ |
Prop 65 Label (EN/FR)
ETL only |
| 16 |
HW2340 |
Screw 6/32 x 3/8" Taptite |
| 17 |
7191A4114 π¨ |
Driver box housing top |
| 18 |
HWM1832 |
Screw M2.5 x 6mm |
| 19 |
7191B5612 |
Power supply |
| 20 |
7191A4011 π¨ |
Control knob cap |
| 21 |
7191B5603-CFG |
LED driver PCB |
| 22 |
HW6759 |
Strain relief - LED output |
| 23 |
7191A4115 π¨ |
Driver box housing bottom |
| 24 |
HW6760 |
Strain relief - mains input
(qty 2) |
Burner assembly
Important: if your LED chip doesn't look like this drawing, see "Conversion kit" below!
Complete burner assemblies
| 2700K Gallery |
7063K1027 π¨ |
| 3000K |
7063K1028 π¨ |
| 3000K Gallery |
7063K1026 π¨ |
| 4000K |
7063K1029 π¨ |
| 5000K |
7063K1030 π¨ |
Note: complete burner assembly comes with the black/red LED wires with bare ends, inside the fibreglass sleeve, ready to be terminated in the driver box. See also Repair Guide
π¨Complete burner assemblies are available in black or white. For other colors, contact ETC tech service
Burner assembly components
| No |
Part Number |
Description |
US |
EU |
UK |
| 1 |
7063A4030 |
Glider piece |
| 2 |
7063A3023 |
Bracket 2 |
| 3 |
HWM304 |
Screw M3 x 6mm |
| 4 |
7191A3062 |
Lens retainer spring |
| 5 |
7063A4091 |
Reflector lens |
| 6 |
7063A3066 |
Reflector |
| 7 |
7063A4065 |
Reflector shim |
| 8 |
7063A3045 π¨ |
Housing metalwork |
| 9 |
HWM305 |
Screw M3 x 8mm |
| 10 |
7063A4092 |
COB holder insulator |
| 11 |
7063B7019 |
COB holder 10" wires a |
7063B7020 |
COB holder 14" wires a |
7163B7119 |
COB holder 17" wires a |
| 12 |
CR669-F |
LED 2700K Gallery |
CR682-F |
LED 3000K |
CR670-F |
LED 3000K Gallery |
CR684-F |
LED 4000K |
CR673-F |
LED 5000K |
| 13 |
7063A4090 |
COB thermal pad |
| 14 |
7063A3044 π¨ |
Rear end/heatsink |
| 15 |
HWM1011 |
Screw M3 x 12mm |
| 16 |
7063A3046 π¨ |
Strain relief |
| 17 |
HWM2105 |
Screw M3 x 10mm |
| 18 |
W6470 π¨ |
Fibreglass sleeve
(order 1 foot per fixture and snip) |
| 19 |
7063A4083 π¨ |
Handle label Gallery b |
7063A4059 π¨ |
Handle label 3000K c |
7063A4078 π¨ |
Handle label 4000K |
7063A4079 π¨ |
Handle label 5000K |
| 20 |
7063A4054 π¨ |
Rear handle |
a Most fixture types use 10" or 14", if unsure, ask tech service or over-order and snip
b Has tick boxes for 2700K and 3000K
c 3000K label just says "LED"
Shutter barrel
Complete shutter barrels
| Original (non-Plus) |
7063A2000 π¨ |
| Source 4 Mini Plus |
7163A2000 π¨ |
Note: original and Plus are functionally identical, but have the correct sticker for the type
Shutter barrel components
| No |
Part Number |
Description |
US |
EU |
UK |
| 1 |
HWM1142 |
Screw M3 x 6mm
(slot cover) |
| 2 |
7063A3019 π¨ |
Gobo slot cover |
| 3 |
HWM1684 |
Screw M3.5 x 14mm |
| 4 |
7063A3033 π¨ |
Top half metalwork |
| 5 |
7063A2011 π¨ |
Shutter assembly a |
| 6 |
7063A3034 π¨ |
Bottom half metalwork |
| 7 |
7063A4037 |
Product sticker
(original, black) |
7063A4043 |
Product sticker
(original, white) |
7163A4004 |
Product sticker
(Plus, black) |
7163A4004-1 |
Product sticker
(Plus, white) |
| 8 |
7063A4020 π¨ |
Shutter blade handle (single) |
a Shutter assembly comes as shown, with 4 blades and 3 blade handles. Order 4th blade handle separately if needed
