Moving hoists with a remote go while using a QT Preset
The hoist does not move with the remote go while in manual mode of a QT Preset.
If you are running QTPreset code 1.52 or earlier this is normal behavior.
To move the hoist you need to use a target move, a trim, or  a preset.
If this does not fix the issue please call rigging tech support.
