Connect a Sola series fixture to a Hog 5 console via ArtNet or sACN
How to connect a High End Systems Sola series fixture to a Hog 5 console via ArtNet or sACN.
Steps to Solution
On the fixture
  1. Select the input
    1. Navigate to Set
    2. Select Input
    3. Choose ArtNet or sACN
  2. Set the universe number and make note of that universe number
    1. Navigate to Set
    2. Navigate to "Set Universe"
    3. Change the universe to your desired universe
  3. Make note of the fixture's IP address
On the Hog 5 console
  1. Launch the show
  2. Change the FixtureNet IP address to be in the same range as the fixture's IP address
  3.  Open the network window
    1. [Setup] -> (Network)
  4. Open the processor settings
  5. Select the output tab
  6. Press add mapping
  7. Select the starting and ending universe you want to add for output for
  8. Select the protocol you want to output (sACN and/or ArtNet)\
  9. Ensure the hog universes are routed to the proper sACN and/or ArtNet port(s)
