Front Panel Size Adjustment for Hog PC
The Hog PC front panel (Virtual console interface) is too small to use
The front panel is resolution-based. to make the front panel larger, set the screen to a smaller resolution. To make it smaller, set the screen to a larger resolution.
It is recommended to use standard 1920x1080 resolution for Hog PC. 2k and 4k resolutions are not supported.
- Press the Windows Key
- Type "Display "
- Adjust the resolution accordingly
