Full Boar 4 Touchscreen Calibration Utility Remains Open in Hog v5
On Full Boar 4 consoles, the touchscreen calibration utility may remain open after both internal touchscreens have been successfully calibrated. This behavior can occur when External Display 1 is enabled and an active DisplayPort-to-DVI adapter is connected, even if no external monitor is attached.
Explanation of Issue
The calibration application determines completion by detecting and calibrating all connected displays. Because the active adapter reports itself as a connected display, the system identifies an additional display and continues waiting for calibration input. As a result, the calibration utility does not automatically exit after the two internal touchscreens have been calibrated.
To complete the calibration process, press Enter to exit the calibration utility after calibrating both internal touchscreens. This same display detection behavior may also cause Hog OS to report an additional display as connected when an active DisplayPort-to-DVI adapter is present.
