Hog PC Prompts for Uninstall when attempting to Install
When attempting to install Hog PC the installation displays a Modify Setup prompt for uninstall instead of install.
Explanation of Issue
This behavior occurs when the same version of Hog PC is already installed on the computer or is still registered in the Windows installation registry as an installed application.
Proceed with the Uninstall procedure as prompted and then re-run the installer again to complete the install.
If the issue persists after uninstalling, verify that the previous installation was completely removed from Apps & Features and that no pending system restart is required before running the installer again.
