SMPTE/LTC and MIDI Configuration for Hog Consoles
SMPTE/LTC or MIDI not outputting on new generation Hog V5 Consoles (Tour, Stage, Flex, and Gig).
  • V5 Consoles use different internal devices than V4 hardware.
  • Mappings for newer hardware have moved within the software.
It should be noted that the LTC Diagnostic (Test LTC Input) will only work with the older Hog 3 LTC Widget and Hog 4 LTC/MIDI Combo Widget. It will not work with the new hardware used in the new Hog Platform.  (Tour, Stage, Flex, and Gig)
  • The tables below will explain mapping Hog 3 and Hog 4 Widgets as well as the new generation V5 Hog hardware when using the internal and external devices.
  • The tables below list the timecode devices compatible with Hog software and where they are configured.
Built-In Timecode Devices Where to Configure
Hog 4 / Hog 4-18 / Full Boar 4
Internal SMPTE
Network Window / Processor Node Settings
Internal MIDI
Network Window / Console Node Settings
Tour Hog / Stage Hog /Flex Hog / Gig Hog
Internal SMPTE
Network Window /Console Node Settings
Internal Midi
External Timecode Devices Where to Configure
ETC Response MIDI Gateway (USB)
ETC Response SMPTE Gateway (USB)
Hog 3 Series USB LTC Widget
Network Window /Processor Node Settings
Hog 4 Series Combo LTC/MIDI Widget
MIDI: Network Window / Console Node Settings
SMPTE: Network Window /Processor Node Settings
Any Third Party “USB MIDI Class” Device
Console Node Settings:
Processor Node Settings:
