BIOS Settings, Road Hog 3
Accessing the Bios
  1. Attach a keyboard to the console and power on the console
  2. During the boot process, press and hold the DELETE key on the keyboard
  3. When prompted to enter the BIOS password, enter hesipc
    The BIOS setup utility will open
Road Hog 3 has 2 different modetherboards.
AIMB-562
The following changes need to be made to each section of the BIOS in the Road Hog computer when using an AIMB-562 motherboard. After making the changes, press F10 to save the configuration and exit.
Main
  • Adjust system time & date
  • Legacy Diskette A: Disabled
Advanced
  • Chipset
    • Graphics Adapter Priority: PCI Express/Int-VGA
  • Onboard Devices Configuration
    • HD Audio Controller: Enabled
    • Onboard PCIEX GbE LAN: Disabled
    • Serial Port1 Address: Disabled
    • Serial Port2 Address: Disabled
    • Parallel Port Address: Disabled
Power
  • ACPI 2.0 Support: Yes
  • APM Configuration
    • Restore on AC Power Loss: Power On
  • Hardware Monitor
    • CPU Fan
      • Profile Mode: Silent Mode
Boot
  • Boot Device Priority
    • 1st boot: Hard Drive
    • 2nd boot: Removable Device
    • 3rd boot: USB CD-ROM
  • Boot Settings Configuration
    • Quick boot: Enabled
    • Full Screen Logo: Disabled
    • Wait for 'F1' if error: Disabled
ASUS P5B
The following changes need to be made to each section of the BIOS in the Road Hog computer when using an ASUS P5B motherboard. After making the changes, press F10 to save the configuration and exit.
Main
  • Adjust System time & date
Advanced
  • Chipset
    • Northbridge Configuration
      • Initiate Graphics Adapter: PCI/IGD
  • Onboard Devices Congifuration
    • Onboard 1394 Controller: Disabled
    • Onboard PCIE GbE LAN: Disabled
    • JMicron SATA/PATA Controller: Enabled
Power
  • ACPI 2.0 Support: Enabled
  • APM Configuration
    • Power On by PCI Devices: Disabled
    • Power on By PCIE Devices: Disabled
    • Power on By PS/2 Keyboard: Disabled
  • Hardware Monitor
    • Fan Profile: Silent
Boot
    • 1st boot: CD-ROM
    • 2nd boot: Hard Drive
    • Quick Boot: Enabled
    • Full Screen Logo: Enabled
More Info:
  1. Road Hog 3 bios documents attached here.
  2. There were two different motherboards used in RH3. Settings for both are attached below.
