Button Strip PCB on display, Hog 4-18, repair or replacement
If there is a problem with the button strip at the top and bottom of the displays on Hog 4-18. The display will need to be sent to High End for repair.
The PCB is mounted to and cannot easily be removed from the display, and may be best for High End to perform the work.
The Display / Touchscreen Assembly has the button strip included and mounted.
The right Display / Touchscreen Assembly is part number 6102K1006
The left Display / Touchscreen Assembly is part number 6102K1007
