DMX x 4 Output PCB, correct service part numbers per console.
The part number printed on the DMX x 4 Output board is not the correct service part number, 80030093EF is for an un-programmed board and will not work.
The correct part numbers are below.
PCB, DMX Output x 4. Needs to be programmed, use service p/n below
- 80030097EF for a Road Hog 4, Full Boar 4, or Hoglet.
- 80030109EF for a Super Widget.
