New part numbers for Full Boar, Road Hog, and Hedge Hog motherboards
I need to replace the motherboard in my Hedge Hog, Full Boar, or Road Hog console.
The AIMB-581 motherboards we have used for years are no longer available.  You will need to order the new AIMB-586 motherboards from us when it's time to replace them.  If your console is an older model, you will likely have to replace the displays as well.  Please have your serial number handy when ordering.  Below is a table that outlines the part numbers and serial number dividing lines.
  1. Use serial number to determine your part number
  2. If factory installation is not required, we can ship the parts to you
  3. If factory installation is required, please contact Hog support or local HES dealer to set up an RMA Non-warranty Repair
Related Links/References
