PCBs, Master Wing 4 Front Panel and Front Panel Processor boards correct service part numbers.
The numbers silk screened on the Master Wing front panel, and front panel processor boards are not programmed and will not work. The correct service part numbers are below.
  1. For the Front Panel board use part number 80040061EF
  2. For the Front Panel Processor board use part number 80010255EF
