PCBs, Playback and Program board correct part numbers, Full Boar 4, Hog 4, and Hog 4-18
The part numbers silk screened on the PCBs are not the correct part numbers. They have not been programmed and will not work.
Use the part numbers below
  1. Playback PCB, use part number 80040050EF
  2. Program PCB, use part number 80040048EF
