Resetting the CMOS on a Hog Console after changing the BIOS Battery: AIMB-586 motherboard
After changing the BIOS Battery on the Console, you will need to boot into BIOS and update the Time and Date. If your console has the AIMB-586 motherboard you will need to take an additional step to get the console to boot. The motherboard requires two pins to be shorted to reset CMOS.
If you have a console with a serial number AFTER AND INCLUDING those listed below, your Console has the AIMB-586 motherboard.
- Full Boar: 720051007
- Road Hog: 720111103
- Hedge Hog 4: 720064002
Required Tools
- USB Keyboard
- Screwdriver (Phipps or Flathead does not matter)
- Power on the Console
- Using a Screwdriver short the two pins outlined in the below images
- The Console will boot, and you will see American Megatrends displayed
- Using the F2 Key on an external keyboard boot into BIOS
- Update the Time and Date
- Save and Exit
- Console should now boot and operate correctly
A Top View of the AIMB-586 MB
A Close up View of the two Pins that need to be shorted
