Faders on a Hoglet or NanoHog4 do not control Hog 4 PC faders
Hoglet faders do not control the faders in Hog 4 PC. The programming buttons on the Hoglet work, but the playback side does not work.
The Hoglet 4's playback wing is not assigned to a playback bar in the control panel.
  1.  Open the Control Panel
    If inside the show, [ Setup ] ( Control Panel)
    If at start screen, ( Control Panel)
  2.  Go to the "Wings" tab
  3.  For the appropriate playback bar, click the drop down menu for Dock Assignments
    Docking assignment
  4.  Select the wing that you want
    1. If you are mapping multiple wings, you can click on the beacon icon after selecting the wing to light the "Choose" buttons on the wing.
  5.  Tap on Dock
  6. Click "OK"
