Widget reports "Needs upgrade" when mapping
When a single universe Hog DMX widget is being mapped in the DP 8000 settings, next to the ID there is red text that says "Needs upgrade"
This is usually caused when using a Hog 2 widget that either needs upgrading or has lost it's upgrade.
If the widget has not been upgraded and the serial number begins in 25, you can purchase a widget upgrade from your local HES dealer. You will need the following:
  • Serial number - on the bottom of the widget
  • Widget ID - found in the Widgets tab of the DP 8000 settings when assigning the widget to output a universe.
If the widget has been upgraded before, please call High End Systems support with your serial number and widget ID.
