Linking Devices to Multi-Channel Controllers
Echoflex ELED2 and ELED3 products have multiple channels - how do you link a device to a specific channel?
Description
The multi-channel controllers have onboard LED indicators that can output three colors. The colors define which channel is currently in link mode, and they match the color of the dimming wires for that channel.
For example, If the red LED is blinking, channel 1 is in Learn mode. The output with the red stripe will be oscillating, dimming the lights up and down.
ELED2/3 LED colors:
Channel 1: red
Channel 2: green
Channel 3: blue (ELED2: channel 3 on the ELED2 does not have a physical output or wire associated to it. This is the digisal CCT set point channel)
Refer to the controller's documentation to understand what type of device each contorller will support on each channel.
Procedure
  1. Press the controller's [LEARN] button once. The red LED will start blinking once per second.
  2. Press the [LEARN] button again for channel 2; if using an ELED3, press [LEARN] a third time for channel 3.
The controller will exit learn mode with another button press on the last channel or after 30 seconds of no Teach commands beinr received from stations.
Video Walkthrough
