Echoflex Sensors with batteries
Question
Which Echoflex control products need a battery or have a battery option? What battery do these products use?
Answer
Many Echoflex Sensors support an optional battery power source in addition to their primary solar power source, and a few control products require batteries. A full chart of equipment that can or needs to use a battery is below. While you can purchase these batteries via your ETC dealer, you can also find any of these batteries at your local hardware store.
Equipment Optional Battery Required Battery Battery Type
KSS-UW Keycard Switch   X CR2032
MBI Multi-Button Interface Switch Station   X CR2032
MC-31 Window Door Switch   X CR2032
MOS-DT Motion Occ/Vac Sensor Dual Tech X   CR2032
MOS-IR-A Motion Occ/Vac Sensor PIR 1000sqft X   CR2032
MOS-IR-B Motion Occ/Vac Sensor PIR 1900sqft X   CR2032
MOS-IR-C Motion Occ/Vac Sensor PIR 6300sqft   X CR2032
MOS-MT IoT Sensor X   CR2032
OWS-BTY Wall Switch Sensor w/ Battery (PIR and Dual-Tech)**   X 2x AA Energizer Lithium
RCS Occupancy Sensor (PIR and Dual-Tech)   X CR1632
ROS Resonate Occupancy Sensor X   CR2032
RVS Vacancy Sensor (PIR and Dual-Tech) X   CR1632
TAP-21 Light/Photo Sensor X   CR2032
TAP-31 Light/Photo Sensor X   CR1632
TAP-41 Light/Photo Sensor X   CR1632
WTC Wireless Time Clock   x CR2032
**Note: regarding the OWS-BTY: this is the battery-powered variant of this equipment. There is another variant that uses line voltage, but it is a different piece of physical hardware.
**Note: The MOS holds a full charge for up to 7 (DT) or 9 (PIR) days in complete darkness. The RVS/RCS holds a full charge for 2-5 minutes. Because of this, it necessary for the RVS/RCS to have a CR1632 battery for Auto ON operation. The RCS is identical to the RVS with the addition of a battery to provide power for support of auto-on occupancy sensor applications.
**Note: A CR2032 coin battery must be installed in the MOS-IR-xC sensor for use in high bay applications.
