Which conductors from Echo CAT5 termination boards are used for Echo bus wiring?
I am using Echo CAT5 termination boards by ETC but then route to an 8-pin CUI connector. Which terminals are used for the Echo Connect bus wiring?
Two conductors each are used for +, -, and Ground over the length of the cable, and then shorted together at the termination boards. The wiring is as follows:
Positive: Orange + Orange/White
Negative: Blue + Blue/White
Common: Green + Green/White
