How Many EchoTouch Interfaces Can I Have Per Echo System
Answer
In a single Echo system, there may be up to 16 EchoTouch interfaces connected. They may be assigned to the same space or different spaces. You must add an Echo Station Power supply to the system to enable communication between EchoTouch interfaces on the Echo bus. They do not communicate with each other over network.
When using an Echo Expansion Bridge up to 64 EchoTouch interfaces (16 per segment) can be connected across multiple Echo systems.
Networking EchoTouch
If networking the EchoTouch interfaces, it is important to give each EchoTouch a unique IP address.
