How to save an E-ACP Configuration and Dimming Configuration to USB
Why Should I backup my Echo E-ACP Configuration?
Keeping a backup of all your configurations is always a good idea.  It gives you a point to return to should something go wrong in your system, and allows you to easily load configurations into a loaner processor or replacement if necessary.
It is important to do a backup whenever you are about to make a system change, like a firmware update, as well.
How do I backup my E-ACP Configuration?
Backup can also be performed to SD Media.  If you choose to use an SD Card, please choose SD instead of USB in the menus mentioned below.
  • Insert a USB flash drive into the USB port at the front of the Echo Processor.
  • Press Check to enter the main menu.
  • Using the wheel around the check (like an old iPod) to scroll down to File Operations.  Press Check.
  • Choose  Save Rack Configs and press Check.
  • If you would like to rename the configuration, you can do so here by appending an number other than 1 to the end.
  • Select Save to USB Media and press Check.
  • The processor will now save the configs to the drive, which may take a few minutes.
