All on Mode not working on PCP Mk2
When holding the Control Button clipboard_eae45bb5c8850300779e5198d55e60e7e.pngon PCP Mk2 devices, loads are not forced on as in previous builds.
Explanation of Issue
Previously on Echo PCP Mk1, you could press and hold  the Control Button clipboard_eae45bb5c8850300779e5198d55e60e7e.png to force all of your loads to full. This feature was replaced with double-tapping the Control Button clipboard_eae45bb5c8850300779e5198d55e60e7e.png to do the same thing.  This feature is not yet available for PCP Mk2 software (v4.x.x).”
A known work around is to use the Control Button clipboard_eae45bb5c8850300779e5198d55e60e7e.pngto Set Levels manually on the PCP to turns loads on via the Switching control Menu, which is available to help you adjust output levels, check outputs, and release any previously set output levels.
To manually set levels for specific circuits using the Set Levels menu, follow these steps:
You can access this menu by pressing [Control]clipboard_eae45bb5c8850300779e5198d55e60e7e.png on the user interface.
  1. Use the numeric keypad, including [and] and [thru/#nav], to specify a single circuit or a range of circuits.
  2. Press [Enter]clipboard_e35b7e8b823c6913879548f829b5cf494.png to confirm your selection.
  3. Enter the desired level value.
  4. Press [Enter]clipboard_eb92b2ba35a11779ca2a86270c64e18ba.png to apply that level, or press [Back] to discard it.
When you exit the Set Levels menu, you will be prompted to Release Set Levels. You have two options:
  • Select "Yes" to return all set levels to their default values.
  • Select "No" to keep all set levels unchanged until you choose to release them.
ETC is always working on new and exciting things! We hope to add this feature back in later builds.
