Load Shedding with Always On Relays in ERP-FT
Question
When a circuit is set to "Always On", will it turn off in a Load Shedding situation?
Answer
No, it will not.  "Always On" is intended to be as if you removed the relay and just had a breaker sending out hot power.  Therefore the only way in any situation for that circuit to be turned off is manually.
