ERP v3.0.1 Config Files Cannot be Loaded at v3.1.0
Some configuration files saved at v3.0.1 do not save correctly from the processor.
Some configuration files saved at v3.0.1 will not load onto a processor running v3.1.0.
This is a bug in software v3.0.1 that affects configuration files using the Timeclock options with events scheduled to occur "at Open" or "at Close".
Unfortunately there is no work around for this bug.  The configuration will not save correctly from the processor in v3.0.1, so it will not load properly to any other version on update.  A Quick Rack Setup will be required and a new config built.
**This is only an issue in v3.0.1.
