Echo Room Controller LED States
Color State Description Notes
Power LED
Blue Solid Power is OK
Blue 3 blink pattern Software is loading from microSD card
Station Power
Green Solid or blinking (activity) Echo Station bus is active
DMND RESP (Demand Response)
Green Solid Demand Response Input is closed
Contact In
Green Solid Contact Input contact is closed
EMERG (Emergency)
Red Solid Emergency (UL924) contact is closed and/or normal sense power is lost.
Red 2 blink pattern Bootloader mode
This indicates that the unit either has lost its software, or there was an error in the software update process.  Contact your ETC dealer or ETC technical services.
All LEDs
Same as above respectively 5 blinks then unit reboots Successful restoration of default settings.
