Room Controller Contact In Push and Hold and Double-Tap Timing
By using the EchoAccess Mobile App, a Gen 2 Echo Room Controller's Contact Input can be configured as Maintained or Momentary, when the panel is set to Custom mode.
When set to Momentary, you can assign a "push" action, a "push and hold" action, and a "double-tap" action.  In order to trigger these actions you would need to close the contact for a set period of time.
Explanation of Momentary Actions
Any state should be held over 100 milliseconds to guarantee it registers.
If the contact is closed for 100-900 milliseconds (less than 1 second), it is considered a "push" action.
If the contact is closed for 1000 milliseconds (1 second) or longer, it is considered a "push and hold".
If the contact is closed for a second time within 100-200 milliseconds of the initial momentary closure, this would act as a "double-tap" and perform the "double-tap" action.
See the Related Link for action options.
NOTE: This applies only to Echo Room Controller Gen.2.  The Gen 1 Room controller does not offer these options for the AV Input.
